Question about Sewing Machines
Kenmore hand wheel won't come off.
I tried to adjust the screw on the hand wheel knob. Now the screw has come off and I can't find it. That's not the worst of it. I can see a frayed place on the belt and I can't get the hand wheel off to get to it. When I was adjusting the screw the inner knob fell off. I put it back on but probably wrong as it had some kind of slip on guide on the back it seemed in place but now I don't know. It was just having the hand wheel jam-up and not allow the needle post to go up so it wouldn't sew and down now it's worse. Can you help me figure out how to get the hand wheel off so I can try to replace the belt. Then hopefully the crazy thing will sew again.
  • 2 more comments
  • mossgreen Jun 10, 2008
    new problem; I have the knob and handwheel off. I have the belt removed. I don't have the stop screw yet I did find a screw that fits the groove pattern and may be able to be used until I find or replace the machine stop screw for the handwheel knob. I don't however know how the knob goes back on properly after I replace the belt and put the hand wheel back in place.;Does someone know how to do that?
  • mossgreen Jun 11, 2008
    The screw is not called a stop screw, it's a clutch nut screw that goes into the handwheel knob. I was able to find a shop that has the screw and can put it all back together for me. He also has the belt I need for my machine. I appreciate the feedback I received on my handwheel knob problem. It didn't solve the problem but it's all worked out okay anyway. This site being available is a real blessing.
  • gloudy Jul 22, 2008
    The handwheel won't turn - thought it was the foot pedal, got anew one and that does not work either. What next? Have had the sewing machine completely taken apart- see no threads hanging up, reoiled machine.
  • czexrus Jan 04, 2009
    i have an old kenmore sewing machine and have the same problem; the handwheel gets caught up and won't turn. the foot pedal works and goes a couple stitches and it gets held up right away. i took everything apart, removed strayed thread and it still won't work.
    any ideas
  • 1074 Answers
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Posted on Mar 19, 2007
  • 5 Answers
SOURCE: needle thread frays and breaks
hi my names angela ive been a seamstess all my life. and it seems there could be a number of soulutions to your problem.first check your needle is in the correct way with the long ridge of the needle facing inwards.
second check you have the thread threaded correctly and it isnt twisted around twice anywere. and check that it pulls quite freely with ur foot lifted.
third. it could be flaw with ur spool case check it isnt damaged by running your finger along the edges if its catching u can file it down a little with a nail file.
fourth it could be your spool is not high enough in the case. so place ur case on a peice of paper and cut around a circle cut a smaller circle inside and insert it into ur spoolcase if your thtead is pulling to tight then you dont need that solution.
well i hope i was useful to you angela,,
Posted on Aug 21, 2008
  • 323 Answers
SOURCE: Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
Posted on Sep 03, 2008
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
I have a Kenmore 158-3500 sewing machine and cannot get the side plate off near the hand wheel I have removed the clutch wheel but the hand wheel and belt seem to keep the plate from coming off.
The machine has two belts, one from the motor to a transfer pulley and the second from that pulley to the handwheel. You have to loosen the motor mount (one large screw/bolt) to release tension on the transfer pulley which in turn releases tension on the handweel belt. You will have to take the belts off the transfer pulley to slide the handwheel off (assuming you have already removed knob in the center of the handwheel)
Don't forget to lubricate the shaft of the transfer pulley while you have the end cover off. If this runs dry you will have a problem.
Good luck
Jan 22, 2017 | Kenmore Sewing Machines
My sewing machine stops after about 10 revolutions, the motor is till running but the needle does not move. any suggestions please ?
1. Loosen the screw on the front of the hand wheel, almost completely.
2. Now, tighten the hand wheel control knob. The needle should be able to move now.
3. Tighten the screw. Your hand wheel control knob should be able to be loosened for bobbin winding and tightened for sewing.
Just for information purposes: The hand wheel control knob is usually the small round knob on the front of the hand wheel and is also very shiny.
Oct 02, 2016 | Sewing Machines
How do I add thread to the bobbin
The small box you will turn towards you while you hold the big handwheel. It might me very tight but it isn't going to break by turning hard. Tighten the small screw before you begin. When it is loose you can wind your bobbin.
Feb 23, 2015 | Sewing Machines
The Balance Wheel and the Clutch Release knob will not tighten together again after filling a bobbin. How do I fix this?
Jan 07, 2015 | Brother Sewing Machines
How to tighten or adjust wheel socan sew after threading bobbin
your wheel should tighten enough to make the needle, bobbin, etc to operate. if you loosen the knob the needle, etc shouldn't move. to adjust keep pressure on the knob counterclockwise and loosen the screw. at a point the knob will slide over a hump. you may now tighten the screw and try to use the bobbin wind and sew functons. you may need to do this adjustment a couple of times.
Nov 09, 2014 | Sewing Machines
slacken the small stop screw and remove the centre free motion knob. the balance wheel should now be free to turn independent of the shaft. you will have exposed the friction washer. clean all surfaces and relocate the washer with the two locating lugs facing outwards into the two slots in the shaft and refit the knob and screw. if the screw bottoms on the friction washer remove knob and turn the friction through 180 degrees and try it again
Feb 21, 2014 | Sewing Machines
Model 1400 manual
there should be a small stop screw to prevent the release knob undoing completely. Did you remove the knob and hand wheel?
If so remove it again and ensure the drive belt is fitted on the hand wheel, there is a friction washer that needs to be located in the slots on the shaft before the knob is refitted.
Feb 09, 2014 | Kenmore Sewing Machines
The foot pedal wont move the needle
Ok, I am assuming that you have an old style machine where the hand hand wheel has the larger balance wheel on the outside and inner knob to release the drive to the needle and feed dogs. If that has been removed and not put back together properly it won't work.
There is a special locking washer inside those that have "fingers" pointing to the inside of the circle. They must be fit into the shaft correctly before the knob is returned into place and the little screw is tightened down.
This guy is a bit of a windbag but watch his video... you'll at least see the part I'm talking about. He shows the part at about 9:50 in the video.
Aug 03, 2012 | Sewing Machines
Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Feb 13, 2009 | Sewing Machines
Stop Motion Knob
Dear Jim,
Aug 31, 2008 | Sewing Machines
Sewing Machines Logo
166 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
