Question about GE GSH22SGRSS Side by Side Refrigerator
Refrig is not working
Last month freezer and refrig were not working.
and I opened back of freezer and I melted all frost with the dryer.
and replaced defrost heater and thermostat.
and it worked fine again.
yesterday I noticed it made strange sound
and today refrig isn't working not cool at all. but freezer works fine.
light's on though.
what should I do? please help me.
  • Anonymous Aug 18, 2008
    Same problem, have emptied ice cube tray that had overloaded and I think blocked the cold air flow into refrig. as that is how fridge is cooled, I am now letting the unit warm so as to defrost any internal ice buildup to melt. Waiting for now.
    JO
  • Anonymous Jan 21, 2009
    freezer works fine but refrigerator side not cooling
Trash it
Posted on Jul 12, 2008
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
I have a GE side by side refrigerator, model GSL85JFPHBS. It sstopped working altogether last month. first the refrigerator stopped working, two day later the freezer part stopped working. I had someone...
I think you meant you have a GSL25JFPHBS (not 85).
It sounds like you have a defrost problem. If your refrig. was off for some time, like a day or more, or it was manually defrosted, it would work for about 2 weeks before the problem would re-occuer. This is caused by a build up of frost on the cooling coils, preventing air flow over them. Un-load the freezer and remove shelves and the back wall inside the freezer. Melt the frost with a hair blower, and replace the defrost heater (part # WR51X10055) and for good measure, replace the defrost thermistor (part # WR55X10025) located at the top of the cooling coils.
Mar 21, 2011 | GE Refrigerators
Freezer is slowly getting warmer - water dispenser won't dispense (occasionally) turbo cool won't work
Open freezer door and look for any frost on the back wall inside the freezer. That would indicate a defrost problem.
Disconnect power to refrig. Unload freezer, Remove shelves and back panel inside freezer. Melt frost with a hair blower. Replace defrost heater located at the bottom of the heating coils. (Note: It may look different than the original, but insturctions enclosed with replacement cover that) Might as well replace the evaporator thermister at the same time, as your problem is about 98% of the time one or the other of those parts. The thermister is a white pencil shapped item, about an inch long, located cliped to the top of the cooling coils you just defrosted.
If you don't have the parts on hand, defrosting only will get your refrig working again for several days, while you obtain the parts.
Note: non-water dispensing is the result of the cold air from the freezer not being able to continue over the frost blocked coils, so it migrates back though the return air vent in the bottom of the refrig, resulting in a frozen water line, and often freezing in the bottom bin of the refrig.
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool...
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Aug 21, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Freezer sides works, refridgerator side will not get cool, any quick fix, I am pretty adapt mechanically
There is a good chance that the evaporator on the refrigerator side is frosted up due to a faulty thermal fuse or sensor or both. Since these units have more than one evaporator, there is no damper to get stuck.
May 27, 2010 | Samsung RS2556 Side by Side Refrigerator
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
My son left fridge door open, from 1-2 hours. it doesn't seem to be cooling now. Is there a problem or does it take a while for condensor to come back on?
What has happened is that the evaporator (the cooling coils inside the freezer) have frosted up due to all the moist air which entered the refrig with the door open. This frost has blocked the normal flow of air within the refrigerator/ freezer. Turn unit off, unload freezer, and leave freezer door open for several hours to allow built up frost to melt. Better yet, remove the panel at the back of the freezer and melt the frost off with a hair blower.
Dec 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrige and freezer do not get cold. Freezer is all iced up.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Refrigerators
HELP ME
Remove back wall from inside freezer and melt all frost with a hair blower. The most likely cause of the frost build up is a burnt out defost heater, second most likely cause is the defrost control. Can't give you part numbers because you don't list a model number or even a brand. Melting the frost and not fixing the underlying problem will get your refrig working for a week or so until the frost builds up again.
Jul 03, 2009 | Refrigerators
Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
GE GSH22SGRSS Side by Side Refrigerator Logo
145 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Alan Moore
Level 1 Expert
