Question about ASUS M2N-E SLi Motherboard
Asus m2n sli motherboard
Hello im building a computer and i got the asus m2n sli mother board and i got a 1200 wt power suply i had to make a 4 prong 12v for some of the power cuz it did not come with that connector i hooked everything up and i get 1 error beep . i got a nforce 9800 video card and a 1 tb hard dive a blu ray drive and a normal dvd drive i got 2 sli ramddr2 amd2 processor and a 129 buck cpu fan i cant find the error beep to tell me whats wrong i just get 1 beep for like 1-2 seconds i got windows xp pro but i have no ops on the hard drive yet
    President:
  • 2,351 Answers
That single beep is most likely POST. Power on self test. You're board, Asus M2N-E SLI uses an Award bios. The beep error codes can be found at this link: http://www.bioscentral.com/beepcodes/awardbeep.htm
If you are using a single PCI-E card, check that you have the bios set correctly. Shown on page 4.4.6. Do you have you're memory in slot A-1 & A-2? Check that you have PCI-E set for primary display adapter, pg 4.4.4
For windows XP Pro with out SP2, please disale ACPI in you're bios. After SP2 & updates, you can turn it back on. It's realy odd that you're high power PSU did not come with an ATX 4-pin_12v connector for the board. (Needed for CPU).
This is a standard feature for current PSU's. Can you swap the PSU? Considering what devices you are running. You can easely run a 350w PSU? This swap would only be used as a test. Next test, go into the bios & go to Advanced, CPU configuration, check hardware monitor. Stay here a bit & watch temp settings.
Go over these suggestions. Let me know if any one of these suggestions has helped? Can you see the drive in you're bios?
Luck!
M
Posted on Jun 07, 2008
While connecting web cam to computer (mother board ASUS M2N-E SLI) the message of the system Excess of throughput of USB contrller
The camera needs more power than what the USB socket can deliver - 6 watts. Since a webcam normally uses less than 0.5 watts then either the cable or or the camera itself are defective.
Time for a new one.
Jul 03, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
My video card smoked and now my mother board, without the video card, beeps 4 times at start up. Is the motherboard smoked too.
Try taking the memory out and reseat it one by one as i doubt the motherboard is "smoked" as you say. Beeps are usually an indication that something else is wrong.
Regards.
Dec 11, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Not working 3-pin
Hello ota_cech:
I think you are trying to say that the 3 fans are NOT working.
If that is the case, try this.
remove them all from the board.
try only one fan in the plug.
I think what you are trying to say is that the three external fans are not working from the mother board...if that is the case....
Try by elimination one fan at a time, one may be bad.
Also that plug may be bad as something may have happened to make it have no power.
thanks,
Aug 31, 2008 | ASUS M2N-SLI Deluxe Motherboard
Local area connection, no internet connection
My guess is the LAN port on your motherboard is bad. The simple solution would be to add a PCI ethernet card and disable the one on your motherboard in device manager.
Jun 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E MBOB
remove the processor and ram from the mother board. now connect the smps to the motherboard and on the motherboard. if the problem persists again then u have the problem with the motherboard. if the board gets on then insert the cpu and on the board if this dosent work then their is problem with the cpu. this applies to all the motherboards
Sep 27, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E SLi Motherboard Logo
150 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
