No sound to speakers with power on
I recently moved and just set up my stereo system again. After connecting the 2 speakers to Speaker A jacks and connecting the CD player, I powered it up to try it out. But, I am not getting any sound out of the speakers. Speaker A button is in the on position, and the correct inputs seem to be selected (i.e., CD or Tuner), but no sound is produced out of the speakers. I do get sound out of the headphone jack. What's going on? I have rechecked the speaker connections to make sure that they are correct. The owners manual troubleshooting guide says that the fuse may have blown out. What do you think? How would I verify that? Thanks.
Tim
  • hopkinstim Jun 06, 2008
    The receiver is a DENON DRA-825R. I do hear a click when I power the unit up and then another click a few seconds later after the Muting cycle is complete.
  • 4,234 Answers
I can not help much without the make and model as these units vary quite a bit. Please update this with that info. Also, do you hear a click when you turn on the set? You should here one followed a few seconds later by another. Please update this and I'll get you some possibilites and some things to try.
Thanks,
Dan
Posted on Jun 06, 2008
  • ABRsvcs Jun 06, 2008
    Answered this in the other note you posted.
    Dan
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
Cant figure out how to hook them up
Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
Jun 27, 2011 | Bose MediaMate Computer Speakers
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How do i connect to laptop? i can only hear 2 of 4!
If your laptop hasn't a 5.1 surround card you can't connect them in a true 5.1 surround system way. But if you have a stereo sound card and if you don't care about true multichannel and want just to hear sound from all the speakers you neet to connect the adapter that came along with your speaker set-just plug and match the colors from the speaker plugs with the adapter and buy a jack stereo to 2 rca cable and plug the rca connectors to the adapter and plug the stereo jack to you laptop.
Oct 17, 2009 | Logitech X-530 Computer Speakers
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
LOW VOLUME FROM RIGHT CHANNEL OF STEREO 1 SIDE OF SYSTEM
It seems like the speaker jack tip needs cleaning, or the contact has become bent away from the connector and needs to be re-aligned.  The Passport is a portable system, so after years of plugging and unplugging the speaker jacks may be worn.  Try using the "Stereo 2" connectors. You can also try cleaning the jack with electrical contact cleaner, and. a cotton swab.
Jan 07, 2009 | Fender Passport Deluxe 500watt Sound...
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
181 people viewed this question
 Grubhead
Grubhead
