Question about Bosch Washing Machines
Not draining water. is displying error code F:18
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
This is a drainage error, check your owners manual to see how to clean you drain out.
Sgt 48
Posted on Jun 06, 2008
Error code F-18 on my washing machine
Hello Jill!
Error F18 indicates that your washing machine spends more time draining the water
One of the main reasons is incorrect connection of the drain hose when installing the washing machine.
May 13, 2017 | Washing Machines
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Error code f:18
F18
Drain error detected
  • Check drain pump filter
  • Check drain pump for blockage or restriction
  • Check outlet hose for blockage or obstruction
  • Check drain pump operation
  • Check drain pump wiring
Jan 30, 2012 | Bosch Washing Machines
Error code E 18
make sure there is nothing stuck in the imp[eller, which is the pump at the front bottom of machine. ( make sure it turns freely ) also try draining the machine by way of drain hose in a bucket. if it drains this way ok then fault is waste pipe plumbing blockage. hope this helps
Jan 02, 2012 | Bosch Washing Machines
Alarm F10 is displyed , my washer/dryer doesnt
Hotpoint error code F10 is
"No cold fill. Check that the taps are on or if the drain hoses are kinked".
Has someone turned off the water supply or the isolator valve on the plumbing?
If not, you may have a faulty inlet valve on the machine.
Please drop a comment back on this thread if you require further help or guidance
Jul 21, 2011 | Hotpoint Washing Machines
What does E7 mean, or what area needs repair when E7 code comes up on a Samsung wf306lawxaa ? It won't run, but it will drain and add water. The tub moves when pushed by hand, but I can hear change...
Hi, these error codes are to do with water supply and drain.Check the water supply has not been turned off or is not working for any other reason . Outside work can often disrupt water supplys! Blockages of the pump and filters need to be checked also is the drain pipe at the correct height (at least 18 inches/45cm from floor) and if pushed into a stand pipe , not pushed to far down (12 inches/30cm is usually suffice). If your drain attaches to the sink waste , check the nozzle is clear and drainage is good.
Take care
Jun 25, 2010 | Washing Machines
Sud
This is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Apr 22, 2010 | Kenmore Elite HE4 Electric Dryer
Error code 001. On/off switch trips off after 10 seconds
when you open the front door you,ll find under the disply a smal hole put eny nail in it a doller sign will apeer in the upper left corner of the disply pres
star , 4,star you will see another disply press the right arrow till you find error word press on it and then press star (astresk. the disply will turn off and on again theis error might be from the heater lamp if
it comes again change the hamps
May 08, 2009 | Canon NP 6545 Copier
Whirlpool duet washing machine
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Nov 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
