Question about Kenmore 71121 Air Conditioner
No Cool Air
The air conditioner quit blowing cool air....vent is clean and no water is drip outside the unit...please help I'm in texas
It is done for baby
Posted on Jun 10, 2008
Why does it just blow cool air?
Check outside condensing unit. Should feel warm to hot air blowing out of the top. If cool to outside air temperature blowing off you likely have a refrigerant problem
Apr 02, 2016 | Heating & Cooling
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Rv ac throws the breaker when outside temp gets high, unit works fine at night when outside temp cools down
Clean evap and cond coils
Place hand on a/c if too hot during the day but cool at night
then freon is being restricted in the condensor
Cleaning coils may help days
Put a trickle of water on the condensor during the day for a test.
.If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
My A/C is not blowing hard
That high pressure rest button is most likely it(A breaker from the wind/mess), try resetting it.
Aug 11, 2009 | Ruud UAKA037 Air Conditioner
My ruud silhouette ii gas furnace is blowing regular air. i know nothing about a/c? is it freon?
Check outside unit to see if it is working. If fan is blowing outside put your hand over unit to see if air is warm. If outside unit is running and air is cool. Low on gas or compressor not running. You need to call a service tech to check it out. Also check the brreaker on outside unit. Russ
Jul 23, 2009 | Heating & Cooling
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat) to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me
Oct 09, 2007 | Heating & Cooling
Kenmore 71121 Air Conditioner Logo
107 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
