Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water Dispencer switch is very slow to close off.
GE SBS Profile Performance model
  • tim9926 Jun 06, 2008
    The water dispencer is slow to shut off and drips after use. Water fillter has been changed but didn't help. Do I need a nes switch and is it hard to replace?
    Thanks,
    Tim
  • 828 Answers
The problem may be in the electric valve in back of the refrigerator that supplies the water to the door dispenser. A small particle maybe lodged on the seat of the valve causing the slow closing and dripping. Replacing the water valve assembly may solve your problem. I would also recommend installing an in line water filter before the entrance to the valve.
Posted on Jun 17, 2008
Water dispencer works and stops, works and stops
I have a similar refrigerator and there is a problem with the the water line freezing in the area of the freezer door. You can solve it by removing everything perishable from fridge and shutting it down. I have had to do this twice and it works. We now keep the freezer set at 1 and it has been fine for a year. GE does make a small electric aftermarket heater that goes in the door area if needed.
Mar 27, 2011 | GE Profile Performance 25.2 cu. ft....
GE fridge freezer profile
the fridge needs servicing....if you still have waranty use it.
Nov 12, 2007 | GE Profile PSI23NCR Side by Side...
GE model # GSS25JFMCWW has water to the dispencer,but not to the icemaker.
could be a number of thing,s The device that sends water to the ice/mak is different than the door water the ice maker has it,s own brain (circuit) water in/out some built into the frig itself . The ice /mah send siginal to water valve to send water.. to ice maker sorry icall appl man sorry
Mar 18, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old. I just replace new filter still not working
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
Oct 12, 2009 | GE Profile Performance 25.2 cu. ft....
Water dispencer
Greetings,
Remove the water dispenser assembly and check the pipes
Jun 23, 2008 | GE Profile¿ Arctica® Energy...
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
129 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
