Question about IOGear COMBO ION GHD135C160 160 GB Hard Drive
Iogear problem My Iogear is using my keyboard as its video link. I found that out when I pulled it off the iogear to go directly behind my computer instead because I was unable to use the "scroll lock" double-click combo to go to my other computer.
  • 61 Answers
Hi. What device are you using? I suggest that you check if the keyboard is hooked up to the correct port. You will see underneath the KVM an icon that looks like a mouse and a keyboard. Make sure that everything is hooked up correctly. It should be okay once you connect them properly. Press "scroll lock" twice.
Posted on May 15, 2009
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
I lost the power adaptor on IOGEAR COMBO Ghd
You need to use 12V; 5V Dual power adapter.
You may also need to contact IOGEAR and order the power adapter directly from them. They can deliver it directly to you.
Nov 09, 2009 | IOGear COMBO ION GHD135C160 160 GB Hard...
The software supplied on the disc doesn't run on Vista 64
Here is a direct link to the software download page.
Sep 09, 2009 | IOGear GPSU21 Print Server
Getting IOGEAR GPSU01 to work on Vista 64
If you know the IP address of the print server you can create a TCP/Ip print port. IOGear offers direction on how to create this type of port and here is a link.
Jul 29, 2009 | IOGear GPSU21 Print Server
GCS62 - both computers must be on for this thing to work?
It seems that you KVM switch is not working properly. computers connected to a KVM switch are not dependent to each other. you should be able to work on any of your computers while the others were turned off.
Jun 06, 2009 | IOGear MiniView GCS62 2-port KVM Switch
My Iogear mouse wont work
In order for you to make the mouse work with your computer, please try the steps below:
1. Make sure that you're using fresh batteries.
2. Make sure that the mouse is turned on.
3. Hold down the connect button on the receiver (the mouse cradle) and hold down the connect button under neath the mouse at the same time for five seconds and then release the buttons.
4. Try moving the mouse around and that should work.
Apr 15, 2008 | IOGear (GKM521R) Keyboard
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Oct 20, 2007 | IOGear GCS632U 2-port KVM Switch
IOGear COMBO ION GHD135C160 160 GB Hard Drive Logo
107 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
