Question about Dell D1728D-LS VS17X Monitor
Picture stripe down center of screen
I have a picture stripe down the center of the machine and the rest is black. Do I need a driver?
  • 46 Answers
Is the stripe there when the machine boots up in dos or only when it goes into windows? If only in windows the I suspect a driver problem. If all the time I suspect that the LCD panel itself has gone bad.
Posted on Jun 21, 2008
Screen not working
You would need a new LCD for that laptop.
Nov 01, 2013 | Dell Latitude D610 Notebook
Sounds like it could be a driver problem. I would try to update the driver from the Intel website, and see if that helps. If that doesn't work for you, then the screen itself or possibly the lcd cable or connection on the motherboard may be where the issue lies.
Sep 09, 2012 | ASUS Eee Top ET2400IT-B006E 23.6-Inch...
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Vertical lines down center of Plasma TV
Because of the complexity of these sets, the fault can be much more than just a bad IC. These sets are serviced at the board level. After changing the board, calibration is done as necessary.
The fault may be in the matrix power driver output area, or in the plasma screen back-plane layer itself. This has to be determined by the process of elimination.
I can tell you in advance that this will not be a low cost repair.
Jerry G.
Jan 10, 2009 | Philips Magnavox 42MF521D/37 Television
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
along the sides or the center ? if on the sides check the picture format and see if it changes. If its doesn't go away sound like u might have a defective IC on the ribbon cable that plugs into the plasma panel
Apr 05, 2008 | Televison & Video
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
TV LCD THomson 26"
If what your saying is that there are vertical stripes down the screen, You have a screen drive problem my friend. This could mean you will need to change the entire main board, the screen driver board if it is separate on this set, or the main LCD panel itself. These boards do not have any parts available for them and must be replace as a whole unit. Good Luck
Mar 19, 2007 | Thomson 20LCDB03B 20 in. Television
Dell D1728D-LS VS17X Monitor Logo
187 people viewed this question
Alun Cox
