Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Have a RCA D52W15 w/ ITC222 board. TV will turn on and stay on for about 20mins and then it will shut off. I have been trying to play an Xbox hooked up through component cables. I even tried not connecting the sound cables to see if that was the problem. Right before it turns off the picture flashes black then red then turns off. When I try to turn it back on the green light will come on but will turn off after 10secs. I usually have to wait a couple of hours or even a day before it will turn back on. I have vacuumed and air dusted the circuit boards. When you first turn the TV (and it works) you can hear the three tubes power up (lite crackle sound) but once it turns off you can no longer hear them. Also the TV still has the high pitch humming sound when it isn't working. You know the sound, it sounds like it should be on but isn't. Any help would be great.
  • 146 Answers
Take a good look at the power/deflection board. The one on the left as you are looking the back. You will find 2 ribbon cables that connect the power/deflection board to the small signal board (the one on the right). Look at the connector that the ribbon cables plug into. If they are black in color that is good. If they are white, that is bad. These connectors do cause intermittant power problems ( or a dead set). They need to be replaced. If they are black, take it to a repair shop.
Posted on Jun 12, 2008
When turn tv on it blows fuse on the power supply board
It means you have a power supply problem or high voltage issues. RCA sets are well known to take out a number parts when they break down. I suggest a tv tech and an estimate.
Dec 29, 2010 | RCA D52W15 TV
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Electrolytic caps
Regular caps
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w15 comes on then shuts off
Hi, thank you for visit fix ya.
This is a common problem on this kind tv.
Replace capacitors on power supply.
22000 uf 16V and 220uf 16 V; upgrade to 35V.
For parts, go to:
Any question I will be here.
Thank you
Jul 28, 2009 | RCA D52W15 TV
Wont stay on after power is hit
Hello, I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83
May 30, 2009 | RCA D52W19 52" Rear Projection Television
52 in RCA
The RCA needs a flyback if its an ITC222 chassis which is waht the D52W20 RCA is. You can get a replacement flyback at the following link with free tech support so you can do the repair yourself which is a very easy repair. You need flyback number 259296. As far as the XBOX you should never play any video games on a rear projection TV as it can cause burn in on the CRTs if it is paused. video games are best played on a direct view, plasma or LCD TV. Rear projections like the RCa is not a good idea because of the possible burn in. heres a link to your flyback 259296
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch hdtv model D52W15
Blue CRT has shorts that causing the set to go into protective shutdown.
May 01, 2008 | RCA D52W15 TV
My TV turns off then turns it self back on 3-5 minutes later. We are told it is the small signal board?
rca? d61w130 itc222 ..does the unit flash green led.
itc222 shut down if the processor detects a problem. can be many different things. horizontal output is first thing to check. any sounds, chirps, smell... did it ever work
Dec 19, 2007 | RCA D61W130 61" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
253 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
