Question about Sony KV-27V42 27" TV
UHF problem Thanks for respondingThe TV is using an antenna and is set for antenna. If there is another setting that has to be changed I am unaware of it. Its not real user friendly.
  • Duaine Morin Jun 07, 2008
    Got it. After realizing that your answer was correct, I reset connectioons to the top control board and tried using the remote and was able to change to antenna. Working great, thanks
  • Sony Master
  • 520 Answers
Glad I could help.
Posted on Jun 12, 2008
I have 722 and a ir/uhf remote. Remote is set to uhf. All was ok until about 2 weeks into use and remote does not work unless 6 inches from antenna. I tried wizard numerous times and resetting to ir and...
It sounds like this is TV 1 that you are having this problem with the remote, is that correct? What has changed from when the remote was working till now? Was anything moved like the TV/receiver? You may have some type of interference with the UHF signal. Without getting more specific information, I'm generalizing the trouble shooting steps. Would you clarify if it's TV 1 or TV2. Please post to this site and I will respond back to you.
Ray Calo
DISH Network
Jan 16, 2011 | Universal Remote Control DISH Network...
I have aflx-3202 t.v. what type of h.d. tv antanna can I use thank you
Any set top HD antenna will do if you are not surrounded by hills and mountains, it maust have COAXIAL connector to attach to your TV. HD (ATSC) antenna is the same as UHF antenna (HD (ATSC) uses the the old UHF band for transmitting) but HD sound better than UHF for marketing purpose so they can charge you more with the word HD on the box.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Dec 26, 2010 | Element Electronics FLX-3211B 32 in. LCD...
I just bought a 19av615db, located in Ireland. how do I set up? Not connecting it to sky or anything,just want to get local channels for now?
If you are in Nothern Ireland you will need a UHF antenna, and Republic Ireland you will need VHF and UHF antenna to recieve off the air signals.
Connect the antenna to the back of the TV. Turn the TV on, select "menu" button on your remote and slect TV from TV/Cable menu press enter, go to main menu and select channel set up menu and select auto channel button and when finished press menu button, check your user manual for details.
Jan 03, 2010 | Toshiba 19A25 19" TV
Sk-32h240s unable to get all local channels thru ant. only what whould be the formally vhf channels, not uhf.
UHF needs a UHF antenna most all channel antennas do not work good on UHF,
Try the set at a friends house that does get those channels. UHF is harder to get and that is why a UHF only antenna is needed by most people. Lots of antennas are junk do a search and you will find the 8 bay C/M is rated the best by a large margin.
A good antenna amp at the antenna is also needed it should be a low noise one. A search will show the ones that work best.
The Gov. as much as lied to us and the TV Stations the type of digital they forced on us is the wrong one and millions of people even with a great antenna have lost TV.
Oct 25, 2009 | Westinghouse SK-32H240S Television
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
I'm trying to install an antenna on this model tv but can't seem to get a signal from the antenna to the tv. Is there a setting on the tv that I need to change so I can get vhs/uhf channels?
There should be a selection for setup or channels. It should give you the option for cable or antenna. Next, what type of antenna? Indoor or out door?
Apr 07, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Cannot get uhf stations
I am going to assume you have a Yagi antenna since you did not specify. There is a connection at the top of the antenna that sends the UHF and VHF down the wiring. This could be damaged. You also may need to repoint the antenna. can assist with that matter. If you have another tv connected to the same antenna and it receives UHF then you may have a defective internal component on that particular set. Depending on your location an age of the set it may be cost prohibitive compared to purchasing a new set.
Hope that helps.
Sep 11, 2008 | Televison & Video
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Mar 21, 2008 | Orion STV2763 27" TV
Reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Sep 01, 2007 | Televison & Video
Sony KV-27V42 27" TV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
