Question about Canon imageCLASS D760 All-In-One Laser Printer
Check printer in canon image class d760
Hi all , my copier display a check printer message
help me pls.
my canon image class laser printer/copier in not printing, i have changed the cartridge with a new one. Printer works but not copier, please help.
canon22
    President:
  • 1,257 Answers
This sounds very much like you might have snapped one of the corotron wires...these are very thin wires that apply a charge to the surface of the drum.
they run from the front to the back of the machine just under where the drum cartridge is.the paper passes over it ...you should see a little channel where it should be.
Moisture in paper may cause your copier to jam. To eliminate this problem always reseal the paper package if you don't use the entire ****.Once you have a paper jam, make sure you clear the jammed paper properly.
Posted on Jun 06, 2008
  • Deeps . Jun 06, 2008
    Was this solution helpful .Show your appreciation by rating it.
  • Canon Master
  • 13,433 Answers
There may be a hardware side problem in the printer- scanner, Have you tryed unpluging it for a while and trying again?
    Master:
  • 638 Answers
Scanner bulb or mirrors of scanner must be having some dust on it.its easy to open the upper glass unit of scanner,jst open it carefully n clen the bulb ,mirrors n the calibration strip(black n white strip below the copier glass)with moist cloth.n refit it simply .ur copier will start copying for sure.feel free to ask 4 further asssistance.wish u success.
I need to find a driver that works for the Canon Image Class D760 in vista 64 bit environment.
go to the webpage canon.usa.com and then go to download and choose your machine, the driver will be there.
Mar 19, 2009 | Canon imageCLASS D760 All-In-One Laser...
Image class
Try this:
Issue: ERROR LCD: System Error E000
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Sep 10, 2008 | Canon imageCLASS D760 All-In-One Laser...
According to Canon, the device is not designed to be turned off. So I guess all you should have to do is to unplug, wait a few seconds, and replug. If no power, then you have a more serious problem. However, yo can use this link at Canon USA for further information: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9437#SupportDetailAct
Aug 20, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Reset the unit
Jul 03, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon Image Class 6530 LCD readout is off center
To reset LCD, turn off and unplug unit for a few minutes. Then Plug it back in, turn it on, and it should be OK.
Go here to see this fix:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=268&modelid=13170
Jun 06, 2008 | Canon imageCLASS D760 All-In-One Laser...
Copier/Printer
Canon has a whole range of laser printing models that can copy and print. Most can also scan (b/w and color) into a computer, many have fax capability, and some are network capable out of the box. Prices range from $200 to $1000+, depending on what you want. See them here.
May 06, 2008 | Office Equipment & Supplies
Canon d760 system error e000
I used your "Best solution" and it worked
Thank you,Steven
Mar 04, 2008 | Canon imageCLASS D760 All-In-One Laser...
kindly explain what u did when it mentioned that error ?
Feb 07, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon imageCLASS D760 All-In-One Laser Printer Logo
80 people viewed this question
old marine
old marine
