Question about Denon AVR-485 Receiver
No audio for DVR
I cannot get audio for DVD movies although the sudio for tv, tuner, sd plays fine. I get video and audio for tv but only video for DVD. What do I do? Also , when I test the surround speakers I do not have sound in the rear rt speaker no matter how I adjust the volumes.
    Problem Solver:
  • 6 Answers
You need to check your input sources for DVD as you can choose whether to use the analog or digital input signals. Check out Pg. 26 in the manual...if you are not using any of the digital ports, you should set both OPTICAL and COAX to OFF.
In regards to the speakers, check whether the speakers are not blown...easy check would be to switch them with the front ports... or use a AA battery and tap both poles of the battery.
Also, when testing, are you seeing "AUTO-SR(SB, SL, etc)" when testing the tones? Consider going through the steps on Pg. 24-25 in the manual.
Posted on Jan 03, 2009
Audio video capture
are u able to hear the audio when you play back from your CAM?
Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
Everything was working fine, then the sound quit working when we play the DVD player. Switch back to TV-DVR mode and sound is fine. Change o DVD and it goes silent. We have to turn up the volume on the...
please try to find new firmware for this model, I guess it is HDMI version compilable problem. maybe after update firmware could fix your problem
Mar 17, 2011 | Yamaha HTR-5560 Receiver
Can't record from tv to dvd
I think you would have to run your sat line through the DVR-1600 first (Line In) then connect directly from the DVR to one of your TV Line-Ins (Audio R, Audio-L, S-Cable Video).
And then use the Cyberhome TV Tuner to record off your sat.
Jan 24, 2009 | Cyberhome DVR 1600 DVD Recorder
DVD dialog track doesn't play
it sounds like your center channel or hookup is not working!
Dec 07, 2008 | Samsung DVD-V3650 DVD Player/VCR
Can't record from my digital cable tv to my sylvania dvd/vcr ..........
Depending on the unit your going to need to check the back of the DVR for video out ports... My DVR has VID/HDMI/VCR/1394/SaTa and IR ports I use the VCR out to record with... because on my DVR I can say "Play this movie... now record to VCR and it will only play the movie on those VCR ports not on my TV so all I gotta do is hit record on my VCR... As long as you have audio/video jacks on the VCR. Then even some have it blocked so you can't do that... depends on model. So try recording on the VCR using the video ports instead of the COAX cable.
May 05, 2008 | Televison & Video
Rabbit ears,vcr,dvr,tv
Connect Rabbit ear antenna to VCR, Take Audio / Video Out and connect to DVR, and Audio / Video out of DVR to AV IN of TV. Start Tuning Channels using the Tuner of the VCR, and store them. Now, whenever you wish to record a particular Channel, select that channel on your VCR, and Record on your Blank DVD in the DVR.
Jan 10, 2008 | Televison & Video
Denon 3802 Amp issue
check the output res. from the DVD, your Denon may not pass high res 720p, 1080i or 1080p and also check the component assignment in the Denons setup
Oct 08, 2007 | Denon AVR-3802 Receiver
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
Denon AVR-485 Receiver Logo
116 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
