Question about Danby DCD5505W Electric Dryer
No heat? Hi - my Danby appears to be working normally, but is just fluff drying the clothes when on the most dry setting. I don't feel any heat when I open it up. If the heating element is broken, how hard is it to fix>\?
  • BrentJ24 Jun 23, 2008
    I'm having the same problem. No heat, everything else seems to be working as it should..
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
When i turn dishwasher on it goes to 1 and just stays there.one time a tech reset my old one by pressing three of the buttons but i cant remmember which ones. its a queit partner 1v
Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry.
OR (depending on the model)
Hi-Temp-Heat Dry, Hi Temp-Heat Dry, Hi Temp-Heat Dry.
Hope that work`s. Keep in mind there is a underlying problem to cause the "1" to appear in the display repeatedly, so this is only a short term cheat.
Good luck.
macmarkus :)
Dec 08, 2009 | Whirlpool Dishwashers
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My roper dryer is spinning my electric meter like a top I replaced the heating unit but problem is still there on fluff dry no heat the meter crawls but low or high heat and the meter spins like atop
I am assuming that your talking about how much energy your using. When the unit runs on full heat, your electric meter will spin as you say like a top, this is quite normal. Electric dryers use tremendous amount of energy. Going on fluff your using just the normal 120v and not pulling many amps to run the dryer. However with the unit on high your pulling more amps and are now drawing 240v to operate your unit.
If your clothes are drying than it is not the heating unit.
If your concern is the amount of energy expended, there is always the old clothes line, which is energy efficient and if you live in a part of the world where the air is clean your clothes will smell fresher than if it came from a dryer.
Oct 11, 2009 | Roper REX4634KQ Electric Dryer
Danby Dryer DCD5505 starts and stops continuosly
ITS COMPLETELY NORMAL!!! THATS HOW IT WORKS.
Oct 23, 2008 | Danby DCD5505W Electric Dryer
MY MAYTAG DRYER IS SLOW AT DRYING
Have you checked it for fluff. Also if the vent is blocked it wont dry properly.
Mar 22, 2008 | Maytag HYE3657A Electric Dryer
Danby DCD5505W Electric Dryer Logo
130 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
