Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My picture is off coler and the picture is cloudy
How much does the coolant cost and how much is the labor to fix the problem ( rough estimate ) . I have a new replacement part a Large Signal Panel / Power Board, I a replaced this would it fix the Problem?
  • Philips Master
  • 8,617 Answers
The large signal board has nothing to do with the problems caused by contaminated coolant. The coolant cost about 10 dollars a bottle . Labor charges for a tech could be anywhere from 200 to 600 depending on the integrity of the repair shop. Most wont do it they will want to replace the tubes.
Posted on Jun 16, 2008
You can't change security question and only gives you 2 trys
This is the best estimate. It is a big job.
The average cost for a Head Gasket(s) Replacement is between $1150 and $1471. Labor costs are estimated between $1108 and $1398 while parts are priced between $42 and $73.Get a personalized estimate based on your location and specific car. Estimate does not include taxes and fees.
Parts & Labor Breakdown Labor: $1108 - $1398 Parts: $42 - $73
http://repairpal.com/estimator/hyundai/santa+fe/head-gasket-replacement-cost
Head Gasket Replacement Cost for Hyundai Santa Fe RepairPal Estimate
May 03, 2016 | Cell Phones
What's the cost to repair intake manfold gasket on 2006 gmc box truck 6.0 engine ? 16 ft not sure of model
the gasket set is $50 or less depending on model type, now depend where you seek to have the repair done reflects the charge. dealerships rape you, and if you can live with that then take it to them, I do not go to a dealership unless i need a special clip or snap, never will i buy a vehicle or have service done by one. I refuse giving free money to companies that rape you for their product in the first place. I would tackle that yourself, or go to a reputable garage that gives a flat rate.
I personally would charge you $ 175.00 . Double that or triple that at dealer. Great day for a grease monkey!!!!!
Jan 15, 2011 | GMC G3500 Cars & Trucks
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
SD TECH
Oct 24, 2010 | Mitsubishi WS-55807 TV
MY CAR NEEDS A NEW AXLE AND 4 BRAND NEW TIRES. I WOULD LIKE TO KNOW THE ESTIMATION OF HOW MUCH IT WILL COST TO GET IT FIXED?
At a shop your looking at roughly $60 - $100 dollars a tire mounted and balanced. The drive axle will run you a couple hundred dollars for labor and a couple hundred for the part.
So total you would be in the $500 - $800 dollar range depending on the quality of the tires, the shop you choose, and the shops labor rate.
Oct 05, 2010 | 2001 Kia Optima
I have a JVC rear projection TV. from the frot it looks like the green color is sagging. we took off the back panel & the green lens... it looks like there is liquid under the lens & that it is...
The tv pictures cloudy or hallow?Yes,than the R,G,B CRTS Tubes guns require changing it coolant liquid.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to used.But just R,B,G colors lines mis alignment,colors shadows or 3D pictures,this problems is a convergence problems,it dead.The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 11, 2010 | JVC AV-65WP84 65" Rear Projection...
I am planning to buy 2000 audi A4 with 95000 miles on it? What do I need to check on this car before I drive off the lot?
This info is from MSN autos.
Occasional problems on this vehicle, 4-cylinder engines only, are failures of the Engine, Engine Vacuum Hoses and the Mass Air Flow (MAF) Sensor. Failure of the Engine is caused because the engine oil gels. When proper maintenance schedules for oil changes are followed, oil gelling should not occur. Audi has issued an 8 year unlimited mileage goodwill repair for this condition. The cost to replace the MAF Sensor is estimated at $380.00 for parts and $60.00 for labor. The cost to repair the Engine Vacuum Hoses is estimated at $25.00 for parts and $65.00 for labor. The cost to repair the Engine is estimated at $4,775.00 for parts and $845.00 for labor. The cost to replace the Mass Air Flow Sensor is estimated at $500.00 for parts and $52.00 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Occasional problems on this vehicle are failure of the Comfort Control Module, with 4-cylinder engines only, and failure of the 4-Way Hazard Flasher. The cost to repair the Comfort Control Module is estimated at $290.00 for parts and $65.00 for labor. The cost to replace the 4-Way Hazard Flasher is $31.50 for parts and $91.00 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Apr 06, 2010 | 2000 Audi A4
1999 camry 2.0 liter oil leak behind engine How much a repair cost
These are very rough estimates.
If it's the valve cover it's about one hour labor.
OIl pan two hours labor.
Crankshaft or camshaft seals three to four hours.
Main seal 10 hours.
Feb 13, 2010 | 1999 Toyota Camry
Rack and pinion steering my rack and pinion steering just went on my 1999 windstar. Does anyone know how much this will cost to replace?
On a caravan new rack and pinion cost around 250 plus labor. Probally hour or two labor so at least another 100 there. So that should be a rough estimate for you.
Jan 24, 2010 | 1999 Ford Windstar
Need a rough estimate on how much it will cost to have a cv boot repaired on an 1997 GMC Jimmy 4x4.
A transmission shop would cast about 1 hour labor plus the parts. Labor cost is around $75.00 an hour here, and the Reman CV joint with the core exchange is around $80.00 and without the core exchange $160.00. Hope this helps.So best i can give you an average $225.00 but call around a reputable transmission shop, since they work on this type of repair all the time. Good luck.
Dec 11, 2009 | 1997 GMC Jimmy
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
