Question about LG Flatron 563LE 15.1" LCD Monitor
LG L194WT Monitor suddenly stop working
I was using my cpmputer as usual suddenly the screen just turned blank. theres constant blinking blue light at the lower corner of the monitor. anyone want know what is the problem?
  • Anonymous Aug 08, 2008
    same exact problem here.
  • Anonymous Dec 10, 2008
    My LG L194WT monitor does not come back of stand-by mode. When I try to wake the monitor up, the LED in the monitor faceplate flashes in blue color in a very irregular rhythm.
It is probably indicative of a switched mode powersupply trying to start then seeing a short and then trying to start again...this will cycle continuously until fault is rectified..any component that can drain the powersupply is the need some way of detaching the powersupply from the load (monitor) to see if the power supply its self is the cause and also check if there is a loop back (a pulse) for continuous running.
Posted on Sep 19, 2009
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
Aug 07, 2011 | LG L194WT 19" LCD Monitor
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
you might have a problem with the monitors power source
Feb 24, 2011 | LG L194WT 19" LCD Monitor
I just got my LG L194WT-SF with an older computer and dont know what hapin, but it dont turn on i have try'd difrent power cords but still no power ive seen outher people with same problem but no awsners..
Hi There,
It's used LCD Monitor, right? You can read my Tips about this kind of issue, just click here.
Let me know if there is not clear enough.
Dec 16, 2010 | LG L194WT 19" LCD Monitor
How to open a 17" LG L194WT LCD monitor
Here are the service manuals:
I usually open it at the bottom edge first and work it all the way around using thin flat blade screw driver.
Failed TV and Monitors:
Sep 17, 2010 | LG L194WT 19" LCD Monitor
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
Hp cpus power supply green light constantly blinking
As always verify all cords are plugged in properly. After that it sounds like you power supply went out. It is not that hard to replace. Make sure you unplug power cord. After you remove the pc cover, Usually you just need to unscrew 4 screws for the power supply. Somewhere on the power supply it should say how much watts it is. Anywhere from 200 watts and up. Just replace with exact wattage.
Sep 16, 2009 | HP Media Center m7250n (ED842AA) PC...
My screen keeps going blank after about 2 hours
check the flexible connectors conecciom tambein There is a false contact
Aug 21, 2009 | LG Flatron L1710S 17" LCD Monitor
I have PHILIPS 42pfl5332d/37. I was watching tv, and suddenly the screen goes blank. There's a blue light that turns on when the tv's on, however when the screen went blank, that blue light turned orange...
I don't have that problem, my problem is that I lost my remote control, so I can't configure de channels.. I just have 4.. =S.. I can see the menu, but in the part that say start configuration, I cant activated without the control, I don't know what to do.. aNybody Knows??
May 19, 2008 | Televison & Video
LG Flatron 563LE 15.1" LCD Monitor Logo
639 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
