Question about Olympus FE-190 Digital Camera
My camera is having problems turning on and off.
I cannot think of anything i did to my camera to have caused it to stop working. I havent dropped it, gotten it wet, got sand or dirt in it or anything. The problem is that when i try to turn it on, it will either
1. Turn on for just a few seconds, and then turn off (the lens does not go in)
2. Not turn on at all
3. Do this funky thing where it turns on half way, all the way, turns off a tad bit, and just keeps messing around untill it freezes in the middle.
When it does turn on for a second, its not long enough to snap even one picture. So i try to turn it off. This is another problem. It will
1. Turn halfway off so the lens is half out, and gets stuck
2. Turn off all the way, but the tiny black cover over the lens only closes halfway
3.(with luck) turn all the way off.
It also wont connect with the computer to upload pictures unless i hold down the power button with great force.
A side note* I have charged the battery in full, and this did not solve the problem. I have run the battery empty and re-charged it, and still did not fix the problem.
  • patarena Jul 28, 2008
    I have used 2 different battheries, both charged up, and the camera slides in and out by itself, then shuts off. I can look at a few pictures, but not delete any (that causes a shut off) or take a picture.
My daughter just had the same problem with her FE-190 - really erratic power-on behavior and when it did turn on, the LCD screen was blank. Anyway, I deduced the that the battery, which I think was OK was not connecting properly. So, I made sure the little red tab was locked over the battery and then it all started to work properly again.
I think it is possible with this camera to put the battery in, but it not have a good connection.
Hope that helps...Brian
Posted on Aug 06, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey Mimi_M,
I know you said you didn't damage the camera and it hasn't gotten wet or been exposed to sand or dirt, but the most common cause of these symptoms are that something is obstructing the movement of the lens such as sand or the lens mechanism is damaged. I would try blowing compressed air into the side of the lens in the hopes to dislodge anything that might be stuck in the lens. If this doesn't work I would have the camera looked at by an authorized repair technician such as bringing it to a Geek Squad® precinct in a Best Buy™ store and they can send it out to be seen by a technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 10, 2008
Camera turns on, shows picture and turns off. Nothing works or moves.
What is the model of your Canon digital camera? Is it a Powershot of some kind?
May 20, 2008 | Canon Cameras
Nikon S3000 dosent turn on
Have you updated the firmware? According to Nikon, when the Rechargeable Li-ion Battery EN-EL10 is inserted in the camera and charged, charging sometimes did not stop after the designated amount of time had passed. Usually, you'll receive the message "Battery Exhausted" if this is the problem... but you could also have a completely dead camera as well.
See Nikon's website, download updated firmware to your camera and install a NEW battery. http://support.nikonusa.com/app/answers/detail/a_id/16873
Nov 29, 2011 | Nikon Coolpix S3000 Digital Camera
Dropped my ps3 , split down middle on the edge between disc drive , and the back, still working. I think its getting hot aswell. when i turn it on neither the red or green lights come on , but it seems to...
the split may not cause any problems as long as it does not cause anything from connecting, moving, or operating the way its suppose to. BUT the overheating will cause a huge problem. depending on how much its overheating and for how long. if it overheats enough then it can cause the wires to melt, the hard drive or cd drive to fail, or anything else you could possibly think of. The split should be that much of a concern but you deffinitaly need to stop it from overheating. you best bet is to either get it repaired ( send it to sony), or replace it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Cracked screen
Hi
The warranty covers manufacturing defects and such, camera stops working completely etc, cracked screen is not one of those things.
You must have dropped your purse or something must have pressed on the screen and caused it to crack.
I think they will charge you for a new screen.
Sep 10, 2009 | Nikon Coolpix S210 Digital Camera
No screen, no pictures
I have the same issue. i believe my mom dropped this too and i don't know what to do. i think the lens go messed up cause it's not allowing to view what im wanting to take a picture at. DARNIT!
Aug 13, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Camera wont turn on.
This kind of problem is hard to understand just what the problem is. That is because many problems can cause such behavior.
Make sure that if this camera has a switch on the battery door or battery/memory card door, that it is not broken or has anything to do with the starting of the camera. One way to test this is to leave the door open, then try to start the camera. If nothing at all happens, then the switch should be okay.
I would like to know about the history of this camera. Has it ever been dropped, been exposed to water, or had an impact on the lens when it was extended. Any of these can lead to problems like what you have stated.
Dropping a camera can do internal damage, not only to the lens, but to the internal connections.
Water damage can cause unlimited kinds of errors and troubles which may be hard to define. An impact to the lens can damage the internal workings of the lens unit to the point that it can be jammed. The jamming will cause such actions as you mentioned. That is because the lens cannot move, cannot be detected as to position and may cause the camera to stop or shut down.
Jul 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Troubelshooting
when digicams are dropped most problems occur because some cables or wiring connections got loose. try taking it to a camera specialist to have it checked because if you open it yourself it might cause more damage.
Jun 19, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
DIGITAL CAMERA
clean the battery and battery compartment with alcohol and let air dry for an hour before inserting battery
Dec 20, 2007 | Olympus SP-700 Digital Camera
Olympus FE-190 Digital Camera Logo
150 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
