Question about Bose Wave music system Multi-CD Changer 3-Disc
CD stuck in BOSE 3 disk stack player
All but 1 disk ejected. Disk #2 will not eject. Keeps saying ERROR
  • mheher Dec 28, 2008
    I have the same problem. I have a CD in the multi -cd changer in slot #2 that will not eject. Disc Error keeps being displayed.
  • Anonymous Mar 31, 2014
    2004 Toyota Avalon cd are stuck they will not eject trying to find a solution
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Posted on Nov 02, 2008
    • smccandlish
      smccandlish Jun 23, 2012
      "If the CD ejects when you do this, the system may need to be serviced." Uh, and if it DOESN'T eject when you follow this weird reset procedure? Should we call an exorcist?
    • smccandlish
      "If the CD ejects when you do this, the system may need to be serviced." Uh, and if it DOESN'T eject after this weird reset procedure, then what? Should we call an exorcist?
    My bose CD player is not working my cd are stuck I don,t why
    Good luck this should do it.
    If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
    PART I
    1. First unplug the power, wait a minute, and then replug power, watching the front display.
    2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
    PART II
    1. Unplug the power cord.
    2. Turn the radio upside down with the front facing you.
    3. Remove the 5 screws from the bottom plate.
    4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
    5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
    6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
    7. Reverse these steps to reassemble your radio.
    Enjoy your cd player again!
    Feb 08, 2015 | Bose Wave Radio
    Cd stuck
    Did you try resetting it?
    Jun 04, 2008 | Bose & Wave& Music System
    A CD is stuck in my bose system How do I get it out?
    From an other web site
    PART I
    PART II
    Oct 09, 2014 | Bose & Wave& Music System
    Player says error
    Most likely your cd/DVD drive needs cleaning, or needs replacement. See a dealer, or send the unit to a Bose service center.
    Dec 15, 2013 | Bose 3 2 1 GSX System
    Bose 3 cd playerdisc error will not eject
    Try to use an old CD...and insert it under the stuck CD...push in slightly while using the eject button...on may models this will release the stuck CD...Hope this helps.
    Nov 25, 2011 | Audio Players & Recorders
    CD STUCK IN CD PLAYER
    The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
    Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
    I own a GMC Envoy and have the 6 disc changer by bose...
    You have to push the Load CD button and then it will say load CD 1, then click load again and then it says Load CD 2, it will  beep when its safe to put the disk in!
    Mar 16, 2009 | Bose 3 2 1 GSX System
    Can't get a dvd to eject from from a Lexus cd player
    basically just carefully insert another CD into the slot, but only about 1 to 2 inches of the disk and keep jiggling the disk around and pressing the eject button.
    This was a suggestion for the lexus owners club wed site.
    give it a try and if it doesnt work let me know and I will try to find something that does.
    Jan 10, 2009 | Bose & Wave& Music System
    Cd stuck for good in bose 3-2-1 (first edition)
    This is an Update to my above problem:
    I've managed at last to pry open - with a huge scredriver - the very sturdy black metal clasp that holds down the cd-dvd driver onto the shaft. Now I could lift it up, see the small frontal hole that manually frees the disk tray. I stuck in a pin and at last it opened!!
    But... Allas....
    I could see that the "captivated" disk had very deep "skid" mark on its playable side, as if sometihng was carving into it. The same carving happened to a new disk I inserted, although it played and ejected normally - only with strange machnical noises. I think that some of the plastic cogwheels that turn or eject the disk got loose. I stuck them in and now it works fine, but I lost confidence in the machine - fearing it may stuck again or ruin my disks.
    Aug 20, 2008 | Bose 3·2·1 II System
    Cd stuck
    if you are good at opening the player then just follow this steps...
    1.take of the screws
    2.remove the cover
    3.take off the rubber belt connecting the dc motor
    4. now you can take the door out by sliding one white coloured clip
    5.now clean the obstacles in the door way and every where
    use dry clothes..
    6.clean the lens also by using the white petrol or spirit....
    then reassemble just put the cd and play...
    90% it will work
    if you are not good at opening then contact the technician........
    Feb 08, 2008 | Bose & Wave& Music System
    Bose Wave music system Multi-CD Changer 3-Disc Logo
    8,274 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Electro Med Services...
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
