Question about WiFlyer - Portable, shareable WiFi base station for dialup and broadband Internet connections (WF1)
Need manual Okay, I just need the original default password. Both alwaysonwireless and wiflyer.com web sites seem to be defunct as of sometime in May 2008.
  • mbirgen Jun 17, 2008
    Unfortunately, I don't have the factory default password. That is what I need. My manual was lost in the flood and the company seems to be defunct.
F you have forgotten the password, you can reset the WiFlyer to use factory defaults for all settings using the following procedure. Need manual - leading.gif leading.gif 1. Disconnect the power cable from the back of the unit. leading.gif leading.gif 2. Press and hold down the "quick connect" button. Need manual - leading.gifg src="http://i.fixya.net/uploads/images/leading.gif" alt="leading.gif" class="h_mi" /> Need manual - leading.gif leading.gif 3. Re-apply power while continuing to hold down the button. leading.gif 4. Release the reset button once all 5 lights have come on and theNeed manual - leading.gifeeped 3 times. leading.gif 5. If unit does not beep (volume off), wait for the lights to start coming on a second time before rNeed manual - leading.gife quick connect button (about 12 seconds). leading.gif leading.gif Note:
Resetting to factory defaults will remove any custom configuration, including access numbers, that you have entered and you will need to configure the base station again.
Posted on Jun 15, 2008
What is the password for ATT304 for wifi
Contact ATnT for default password and reset instructions.
Nov 23, 2014 | WiFlyer - Portable, shareable WiFi base...
How do I crack activation key for guitar magic evolution
Address:The Old Schoolhouse Magazine
' PO Box 8426 ' Gray ' TN ' 37615Phone: 1.888.718.HOME
Email:Publisher@theoldschoolhouse.com
Web: www.TheOldSchoolhouse.com
customer support above
Nov 20, 2014 | Computers & Internet
Wireless key not authenticating
1.Reset router back to default settings,reset button on router.
2.Then use default key on the back of the router to configure.
3.Once you're in just change to the your preferred password.
Apr 26, 2014 | WiFlyer - Portable, shareable WiFi base...
Need user and password of canon ir3170
here's the original disk http://www.precisionroller.com/manuals-for-canon-imagerunner-c3170u/products.html. Try these Default system password: user:7654321 , psw:7654321 Default technician password. 11111111 Control panel password: user: Administrator , psw: password
Oct 30, 2012 | Canon ImageRUNNER 3570 Copier/Printer
How to clear call for p/m fuser web on a panasonic dp8035
not a great idea seeing that the fuser web is needed to clean the hot-roller, so i would suggest to have an authorised dealer replace the web. if however the web has been replaced , and you just need to clear the counter, this is what to do:
get into service mode by pressing and holding the "function", "original size" and "3" buttons in rapid succession. sometime a bit tricky.you should see F1 self test on the screen.if not, press the yellow all clear and try again.
once in this is what the manual has to say:
"Call for P/M Fuser Web" (Default: 240K)
1. Perform the P/M (Preventive Maintenance). Refer to Section 3.3 and 3.4.
2. Press the "Function", "Original Size (Ledger/A3)", and "3" keys simultaneously to enter the Service
Mode.
3. Enter the password, and select "OK" button (default password is 00000000).
4. Enter the Copy Service Mode F5-73 (Fuser web) PM cycle and change to the desired value.
5. Press "Function" and "C (CLEAR)" keys simultaneously to exit the Service Mode.
hope that helps>
mario
Oct 19, 2012 | Panasonic DP-8035 Grayscale Copier
I have a legal copy of 321 studios and need to install it on another computer. However the process requires, internet connection (to a defunct company), Phone call (to a defunct co.) or orginal computer...
If you have legal copy then you can find serial number for registered it.
You can get it from disk cover or disk surface.
Then you can enter that serial number when you install software it ask for serial key so it registered.
But if you are unable to get serial key then drop an email to this software manufacturer web sites supports or login with id and password on that web sites then you can get serial key for register it without internet.
Let me know if you need further assistance.
Thanks for using FixYa.
May 11, 2010 | 321studios 321 Studios DVD X Copy (Backup,...
User manual
There is no user manual available anywhere for your model.Please contact Wiflyer:
http://www.wiflyerhomes.com/ContactUs.aspx
Aug 13, 2008 | WiFlyer WDB20B 802.11g/b Wireless Adapter
Is WiFlyer still in business?
Always On Wireless is down, that seems to be sure.
For the Accelerator there is a solution:
The software is based on the "SLIPSTREAM" -system. You can use any other accelerator software based on that system. I have found the shareware "Nitro Web Accelerator", which can be downloaded from different shareware-providers. The trial runs 14 days, after that it will cost 30 $.
May 27, 2008 | WiFlyer - Portable, shareable WiFi base...
Computers & Internet Logo
260 people viewed this question
Top WiFlyer Computers & Internet Experts
Frank Zabroski
Frank Zabroski
Tom Chichester
Are you a WiFlyer Computer and Internet Expert? Answer questions, earn points and help others
