Question about AMD Multimedia Computer with Athlon64 3000+ (2.0GHz)Processor (AMD64256BMDDR80GBHD) Motherboard
Print delay hi, i have never had this problem before so i am assuming i may be missing a driver or something for my new Brother 7820N printer/fax. when i hit print in my word perfect prgram (windows XP), i could take five minutes before the thing will print. sometimes if i print directly from the internet, it prints immediately. so what can i do to speed up my print onset time? thanks valerie
  • 868 Answers
Uninstall drivers and re install again
Posted on Jun 07, 2008
I assume by software you mean drivers. The drivers for your printer and the Driver Deployment Wizard can be found here:
Trust this is helpful. Please vote. :)
Dec 17, 2010 | Brother MFC-7820N Laser Printer
Cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Fax Confirmation Page
I used another website that allowed me to look at a printable version of the manual I needed.
Dec 01, 2008 | Brother MFC-7820N Printer
I have the Brother MFC-7820, I just purchase a laptop with a Windows Vista. I am unable to use the printer. What do I do?
23/Feb/ 07: Updated the Brother original driver(Full Driver & Software Package) for the following products to fix a driver installation problem: FAX-2820, FAX-2920, DCP-7020, DCP-8060, DCP-8065DN, MFC-7220, MFC-7225N, MFC-7420 ,MFC-7820N, MFC-8460N, MFC-8660DN, MFC-8860DN, MFC-8870DW, MFC-9420C
And here is the link of the updated full driver and software package. After you download this, you should be able to run the MFC 7820 with your new laptop=)
Nov 25, 2008 | Brother Office Equipment & Supplies
Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Not able to send fax to an eFax number
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Sep 05, 2008 | Brother MFC-7820N Printer
Printing from XP to a Brother 7820N as a networked printer
We have multiple 7820s in our office. This would be a configuration problem with your windows XP computer. From the XP computer, open a command prompt and type "ping x.x.x.x" where x.x.x.x is the ip address of the 7820n. Make sure you get four successes. I would then uninstall the brother software and drivers and go to "printers and faxes" in the control panel and manually add the printer.
To manually add a network printer, with it's own print server, on Win XP:
1 Click "Add Printer"
2 Select "Local Printer Attached to this computer"
3 Deselect "Automatically detect and install my Plug and Play printer" then click "Next"
4. Click "Create a new port" and select "Standard TCP/IP" from the drop down. Click "Next". this will open TCP/IP Wizard
5. Type in Printer IP Address next to IP Address (Port name will autopopulate) and click "Next"
6. If wizard finds printer, it will show you "Finish" button. If you get a "Additional Port Information Required" window, something is wrong with your printer or windows xp network configuration.
7. When the TCP Wizard window closes, it will take you back to Add Printer Wizard. Select "Have Disk" and navigate to the \USA\WXP\Addprt directory on your Brother Drivers disc.
8. Select brxpadd.inf and click "Open" then click "OK"
9. Select "Brother MFC 7820 N Printer" from the list and click "Next"
10. Select name of printer, whether you want a default, print test page and DONE!
Jun 12, 2008 | Brother MFC-7820N Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at
Oct 17, 2007 | Brother MFC-7820N Laser Printer
AMD Multimedia Computer with Athlon64 3000+ (2.0GHz)Processor (AMD64256BMDDR80GBHD) Motherboard Logo
35 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
