SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
SOURCE: samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
SOURCE: phone does not detect headset
Put your headset in pairing mode first. Turn it off. Then, press and hold the MFB for some 8 seconds, until the indicator light is steady blue. Then, make your phone's bluetooth application search for new devices. Your headset should appear on the phone screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash rapidly 10 times, and enter the stand-by mode (light flashing every 3 seconds). The pairing procedure should be done only once. After any two devices are paired, just by bringing them within 10-feet from each other should suffice to have the bluetooth link done. Otherwise, a simple press on the MFB should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to pair your headset with your phone.
Regards,
Carlos
