Question about Frigidaire Kitchen Ranges
I have a frigidaire oven model# FEF366DCB, the oven door does not close completely, it appears the the door is a little low so that seal does not sit in the grove can this be adjusted or do i have to buy new hinges.
  • 868 Answers
THEY NEVER SIT REAL TIGHT,BUT SOME CAN.TAKE A TEMPERATURE (SAY 250)AND SEE IF IT HOLDS.THE IDEA IS TO SEE IF YOUR LOSING HEAT OR JUST BAKE SOMETHING TO SEE IF IT IS UNDERCOOKED.YOU CAN CHANGE THE HINGE IF YOU WANT TO BUT I DONT THINK IT IS NEEDED.
Posted on Jun 07, 2008
Frigidaire self cleaning oven FEF365BGWC lock stuck and unable to close oven door what do i do
according to your model #, Your door latch is no longer available. the only way you can get your door to close completely, is to have the door latch removed. You won't ever be able to use the cleaning cycle, but you can still cook with it!
Nov 22, 2015 | Frigidaire Kitchen Ranges
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Mar 28, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Oven door not sealing?
These doors have springs to shut them. If you can figure out how to get to the springs usually you will see that one is either unhooked or unattached at one end. If broken on the end bend another hook into it and add a pice of wire long enough to make up the broken difference.
Jan 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire 40 inch range model #REG46NW-2
OPEN THE DOOR COMPLETELY. IF IT GOES BEYOND HORIZONTAL, THE HINGES ARE BENT FROM EXCESS DOWNWARD FORCE. THEY WILL HAVE TO BE REPLACED.
CHECK THE DOOR HINGE SPRINGS TO MAKE SURE ONE OF THEM ISN'T BROKEN. IF YOU FIND ONE BROKEN, REPLACE IT.
Mar 31, 2008 | Frigidaire PLCF489AC Dual Fuel (Electric...
Oven door will not seal at top.
The same thing with mine. I took apart the door today and found the hinges a little bent. I think it should be ok to bent them the opposite way a little with some mole grips......and then I must remember not to move the stove out for cleaning by the oven door handle again (oops).
Door comes off (unlock hinges and lift up). undo 4 screws on the bottom edge and then two on the inside of the door handle then it comes apart - beware as it's heavy. The hinges themselves come off with two screw each.
Jan 27, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Oven door not closing
I was having the same problem with my frigidaire oven door. I was thinking that it was the seal getting in the way at first, but then I realized that the hinges needed to be repositioned. I wasn't in the mood for that kind of reengineering, so I came up with a better solution. Magnets. Not those **** fridge magnets either. Neodymium magnets. Place them on the upper part of the inside of the door, near the door lock (outside of the seal). You'll only need about three or four depending on the size. (get the fatest ones you can). If you know a computer geek you might be able to get a few free magnets from an old hard drive. I used five of these and I can just about pull the oven out of it's place while trying to open the door. The onhly problem is that heat destroys magnets and I can't say how long these will last because I just figured this out tonight.
Dec 27, 2007 | Frigidaire Ovens
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Kitchen Ranges Logo
641 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
