Question about Bosch Washing Machines
Washing machine error code f04 - Bosch Washing Machines
  • Anonymous Aug 18, 2008
    F04
Ok these machines are great and they make it very simple F04 means cant drain which usually means money or bits and bobs stuck in pump impeller. On the front of the machine remove the bottom right hand plastic cover by hand this is where the access to the filter and pump can be found, you will see a black cap about 3" which can be unscrewed you may need pliers or something to grip it and turn it, have plenty of old towels ready as the water in the machine will begin to come out when you unscrew it(anti clockwise), just unscrew it a little until the water trickles out and mop it up with the old towels until the water stops then continue to unscrew anti clockwise until you are sure the thread is no longer gripping you cant over unscrew so if in doubt just keep unscrewing....then it needs to be pulled out toward you, you will probably need grippers or pliers for this just wiggle it out and remove it, look inside you will see the drain pump impeller, put a finger in and feel for whatever is obstructing it and remove, now use a finger to feel for the inlet that comes into the chamber from the left, use a finger to feel inside this pipe and remove other bits and bobs in the pipeline that were ready to find there way to the pump, once you have removed whatever is in there clean with a rag the thread and scale and make it nice and clean. In your sink wash the screw cap and little white filter piece that is attached to the cap and careful so as not to cross thread it push and then screw it back in making sure the filter solid plastic part is facing toward the inlet pipe you cleaned earlier as its that solid part that prevents (should prevent but didn't or you wouldn't be doing this) large objects finding there way in to the impeller chamber, screw the cap in and restart the cycle and your done, easy repair anyone can do it..... Don't forget to send me your luv if this works for you!!... Nick (at) 2xx.co.uk
Posted on Apr 27, 2009
My brother NX-600 keeps displaying the code F04, if I switch machine off then on again it will allow me to sew, but then stops showing the F04 message agai.
You need to find out what that particular error code means and address that particular issue. It could be something very simple but frustrating, just the same..
Search for:
Make Model error code F04
Oct 19, 2017 | Brother Sewing Machines
Need to know what f04 error code is
Bosch Excel? F04 means the pump hasn't been able to pump out (or at least that it thinks it hasn't been able to pump out). There are multiple possibilities from a clogged hose, to a burnt out motor, to a bad relay or just a bad connection. None the less, I found a blog post that details how to deal with it if you're handy...
http://jgwinster.blogspot.com/2011/07/bosch-washing-machine-fault-code-f04.html
Hope that helps!
Apr 13, 2015 | Washing Machines
What is f4 and f7 error code
F04 Error code is "Pressure switch jammed on empty"
F07 Error code is "Heater relay stuck"
Both would require you to dis-assemble the washer to get to each part for checking / replacing.
http://www.hotpointservice.co.uk/help-and-advice/error-codes/
Sep 03, 2014 | Hotpoint Ultima WF860 Front Load Washer
Indesit washing machine wixe127 has f04 faultcode starts cycle then empties and fills simultaneously
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Washing Machines
I have a kenmore front loader 41744072300 that has error code f04. After replacing the keypad because of an F05 error code. Washer stops after 6 minutes on any cycle. Sears states f04 may be the panel is...
After 2 more sears repairmen. They replaced, motor control unit. Wrong.. Then the computer control board.. Correct.. Did not wait for the Repairman because they may break something else. Only took 1 month to figure this out.. Sears = Bad
Dec 28, 2009 | Kenmore Washing Machines
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Hotpoint wt965 f04 error
F04 indicates that the pressure switch is jammed on empty,
check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an enginner
This really is your only option.
Plz rate my solution
Thanks.
Dec 18, 2008 | Hotpoint Ultima WD72 Front Load...
BOSCH 1400 excell
find the punch hole on plate use pointed object stick in hole and turn
Oct 05, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
1,146 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
