Question about Sony KP-41T65 41" Rear Projection Television
KP-41S4U TV (dead) stand by pulses a few times when the tv is switched on then stops and then after a short while begins to constantly pulse again.But TV is still dead.?
  • mongrelken Jun 06, 2008
    gone through the precess once again and on switch on the
    LED just pulses once then after approx' 8 mins began to
    constantly pulse (one per second) there are no interuptions
    at all the LED just keeps on pulsing non stop.(TV still dead.)
    Regards, mongrelken.
    Dan,
    the Led has stopped pulsing constantly and is now pulsing
    seventeen times with a three second interval then continues
    this cycle.
    mongrelken
i have the same situation and it blinks 17 times after a while.
took the power board out and couldnt find any capacitor leakage , any suggestion?
thanks
cornpoppy2
Posted on Apr 19, 2010
  • 4,234 Answers
THe standby light will blink a code that should be a repeating code. Please post the count here as that indicates which circuit has the fault. That info coupled with the model number above will allow us to explain what is broken and perhaps what parts need to be changed to fix it.
Dan
Posted on Jun 06, 2008
  • ABRsvcs Jun 06, 2008
    17 times seems a bit much, but let me look it up and I'll get back to you. Please note that it is Friday nite and I may not get back to you for a few days. I'm out at a Boy Scout event.
    Dan
Sony KP-51WS500 turns red ,shuts off, led blinks 8 times
Here are the fault codes for your tv and what components are affected:
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I have seen the tube divider pack cause this too, Take the front speaker grill off remove the 4 screws and the panel comes off. There is a pack with 2 red 2 green and 2 blue adjustments, Try turning the BOTTOM red one down 1/32 a turn and see if the symptoms change
Apr 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony kp65wv700 tv blinks 7 times - Horizontal deflection issue is what manual is telling me. My question is what transistor/chips I need to replace and if anyone has done that to fix this problem...
Feb 26, 2010 | Sony KP-51WS500 51" Rear Projection...
Turn off after a few hours
If the TV turn itself off then perform the following steps:
(i) Check if the Sleep timer is activated.
(ii) Check if the Parental Guide prohibits viewing during that time and/or limits amount of viewing time per day.
(iii) Check the batteries on your remote, low battery power may cause random signals from the remote.
(iv) Disconnect all the cables from the TV then reconnect them after a few hours.
(v) Ensure the power cord from the TV is directly connected to a functional wall outlet.
(vi) You may also try resetting the TV to the original factory settings by pressing the Reset button on the remote control supplied with the TV when in Menu.
The following is the information indicated by the blinking patter of the standby/timer lamp on the TV:
2 times : Power does not come on.
Load on power line shorted.
3 times : The TV has entered standby mode.
4 times : Has entered standby state after
horizontal raster.
stopped.
Power line is shorted, or
5 times: No raster is generated.
CRT Cathode current detection
6 times: No picture
9 times : No sound
Furthermore, the TV is equipped with a self-diagnosis function that you can use to determine whether the issue is related to any hardware malfunctioning. Perform the step given below to run self diagnosis:
Quickly press the remote command button in the following order from the standby state.
Display -------> Channel 5 ---------> Volume -(minus) --------> Power ON.
If the Self Diagnosis display numeral "1" for any parameters then a fault has been detected and service will be required.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
No picture, TV dead and the relay on the power suply cliks once
Did you replace these Items?
IC1509(V out) i
Q1505(V Pulse Buffer)
Jun 18, 2009 | Sony KP-53S75 53" Rear Projection...
Hello..i have a sony kp-61v80 tv year 2000
4 times flash of standby light shows that TV has problem in Vertical Deflection area and possible causes are IC1509(V out) is broken and / or Q1505(V Pulse Buffer) is broken.
Please check / test above said IF you have experience of TV repair.
Nov 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-65WV700 DVI-HDTV Issue
From here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Nov 12, 2008 | Sony KP-57WV600 57" Rear Projection...
I HAVE 4 FLASHES
Sep 24, 2008 | Sony KP-53V85 53" Rear Projection...
Have Sony KP-41S4U Projection TV. Am in France and a friend will look at it if I can find wiring diagram (lost). Fault is a 'flashing picture'. Started doing it when background was 'pale/white' but...
Hello Folks,
Thanks for getting back to me. Sorry, but my solution was to sell the TV. Am moving on to a canal boat and am getting rid of all sorts of stuff. Was going to repair TV before selling. I've given the buyer your Website details so you will be hearing from him.
Best regards,
Joe Killman
PS By the way, am living in France. Does that make any difference?
May 08, 2008 | Televison & Video
Tv flickers/blink
Given the vintage of set it might be hard to even get parts for it. And being a Sony, it is traditionally very expensive to repair and not really cost effective. Best bet is to give set a decent burial and shop for a new set.
Sep 19, 2017 | Sony KP-41T65 41" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
