Fuses and relay Suzuki Grand Vitara 2005-2014
For the Suzuki Grand Vitara 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014 model year. Fuse box location. The fuse box is located under the driver's side of the dashboard.
huh
vitara petrop
what on earth is that.?
this is a USA forum , you know that?
and we dont have petrops.
nada
nor know which of 56 suzuki engine you have. at all.
ah Petrol (no P)
so what engine we can not guess, engines or countries here,
you must SAY.
there are at least 3 different engines available for that vehicle. proper lubrication info can be found in the owner's manual. if you cannot find that, call a suzuki dealer.
underneath the engine at the lowest point there is a bolt about 17mm undo drain oil then put 17mm plug in fill the new filter with new oil before screwing back on and place oil around rubber ring on new filter so it seals properly fill with oil to low point on dipstick start car check oil filter for leaks turn car off let oil settle and check level again too much oil in a motor will cause problems so dont over fill hope this helps glenn...........
