Question about Intel D865GBF Motherboard
No display on screen and solid amber light on pcs' power button
I've replaced the motherboard on a gateway 700x desktop pentium 4 computer thinking it would resolve the issue of no display on the monitor and a solid amber light on the computer's power button. I've tried other video cards that I knew were working. I've swapped cables, power supplies, and memory cards and nothing works. I've tried everything but a new processor. Need motherboard for Gateway MX6448 Laptop.
    Scholar:
  • 119 Answers
Well hate to say it but that sort of problem results from a faulty motherboard or processor so if you say that you have changed the motherboard then you problem lies with you processor chip.
Posted on Jun 07, 2008
3 Suggested Answers
DCSE
  • 191 Answers
SOURCE: no display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Posted on Jun 06, 2008
pgh_pa_guy
  • 2992 Answers
To el_cid_132: Did you mean to say a solid amber light on the MONITOR's power button? If, after all you've tried with the computer, you still have no display, it's a pretty good bet your monitor is bad. Try another monitor to verify the computer function. Take a close look at the pins in the monitor's input cable plug. They are pretty easy to bend, and you may have one not making contact.
To Jaffe: It's a simple job to remove the hard drive from your laptop and hook up to another computer to copy anythig off that you want to keep. I don't know what a shop in your area would charge, but it should be reasonable. As for replacing the system board, a quick Google search for "MX6448 motherboard" turned up several sources, price range $250-$300. Usually it's not worth putting a new system board into a laptop unless it's a very high-end model. You can buy basic laptops now for around $400, and you'd be getting brand-new with a warranty.
Posted on Nov 21, 2008
How do I fix problems of Dell computer 780 with power light yellow and black screen?
getnet,
What do the diagnostic led lights show. The diagnostic LEDs are located on the front of the chassis next to the power button. These diagnostic LEDs are only active and visible during the POST process. Once the operating system starts to load, they turn off and are no longer visible. Below is the manual that provides information on what the led pattern shows to help resolve the issue.
Optiplex 780 manual
http://dell.to/1HqoNmD
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 20, 2014 | Dell Computers & Internet
Orange light
A solid amber light means you have an internal power problem. Your power supply has probably died.
May 19, 2012 | Dell Gx-520 Intel Pentium 4 2.8Ghz Desktop...
My computer won't start up and is blinking yellow. How do I fix it?
An steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
Orange light remain on switch after powered on computer
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
If the power button is solid amber, then there is a motherboard failure or a failure in something connected to the motherboard.
Remove any expansion cards and all external connections, if no change replace the motherboard
If the LED is flashing Amber, most likely the power supply
Jul 12, 2011 | Dell OptiPlex 360 Desktop Computer
I have a problem with my dell vostro 200. There's an orange light on the power button and an orange LED on my motherboard which prevent normal display on my monitor. What can I do to solve it?
The power LED if it is flashing AMBER, then the power supply is failing. If the LED is Solid AMBER then the motherboard, or something connected to the motherboard has failed (Video Card, Modem etc)
May 18, 2010 | Dell Vostro 200 Desktop Computer
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Nov 30, 2008 | Dell Dimension 4500 PC Desktop
and if it doesn't
Jun 06, 2008 | Intel Motherboard
Jun 05, 2008 | Gateway (4000779) Motherboard
Intel D865GBF Motherboard Logo
211 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
