Question about Sony Ericsson W710i Cellular Phone
Charger port/screws I have corriosn damage on the charge port of my phone. it is only on the inside part because the outer part of the port that you can see is clean. Plus when I sent it back to the company they took it apart and took a picture of it. you can clean corrosion off with rubbing alchohol and a cotton ball or q-tip, so all i need is to open the phone so that I can clean it. The screws are too small though. Does anyone know what screwdriver I need or a good place I can send my phone to be fixed? Its basically brand new and cost a lot of money. Thanx
  • Jayj09 Jun 09, 2008
    Thanx! Im guna go buy one now and I'll tell you how it works out! THANX AGAIN
    Problem Solver:
  • 12 Answers
Asterisk screw driver.. or a precision screw set
Posted on Jun 06, 2008
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Set is not getting charged
Hi, when a phone does not charge, possible cause forphone not charging is,
: The charger,
and the charging port.
The charger might cause phone not to charge if it is damaged.You can test the charger with another phone if it will charge to confirm if the charger is working.
The charging port can also make phone not to charge, it's located at the low end of the phone where the charger is inserted in the phone.
You can check both to confirm which is faulty.
I think that will help.
Take care.
Oct 02, 2010 | Motorola Mobility RAZR V3x Cellular Phone
The chager part to my phone is not working
Dear Sir\Ma,
Have you tried to change the charger to see whether the charger is the problem and if probably you have done that, then the problem is from the charging port. Two causes may cause this problem 1. Dust or Dirt Try to use a tissue with a pin to clean the charging port, after a well and proper cleaning try to insert the charger to see whether it works, if the phone is still not charging then the problem is that the charging port is damage. 2. Charging port is damage. Get a phone repairer in your area to replace the charging phone for you or go to the phone service center for a repair, they will definitely replace it for you.
Regards
Sep 11, 2010 | Lands Phones
I have the Verizon LGVX8350R phone, it works perfectly but the only thing is that it will NOT charge, I just bought a new charger from walmart 3 weeks ago so its brand new. I did drop the phone on a...
Hi, you will have to test for both to be sure which is faulty.
You can use another charger to test if it will charge or you can use the charger on another Verizon phone to check if the charger is working.
After that, if the charger works, that means the charging port that you attach the charger to the phone will be the problem.
You will need to replace the charging port.
Take care.
Jun 22, 2010 | LG VX8350 Cellular Phone
Motorola v365 won't charge and won't stay with wall power
The reason your phone wont charge might be because there is a problem with the battery, the charger or the charging port.
To test it if it is the battery,
Insert the battery into another phone and try to charge it for a while,
if it does not work, then it is the battery.
All you have to do is to change the battery.
To test it if it is the charger,
Plug the charger to a power supply,
Connect the charger to another phone, to see if it works.
If it does not work, then it is the charger that needs replacement.
To test if it is the charging port,
Insert a new battery, and plug it to a new charger.
If it does not charge, then it is the charging port.
Replace the charging port and it will be okay.
To replace the charging port;
  1. After removing your back cover and battery, remove the four torx 6 screws you see. (When reassembling, the gold screws go at the bottom and the silver screws go back at the top),
  2. With the four screws removed you can now remove the battery compartment,
  3. With the battery slot removed you have access to one of the ribbons which connects the screen to the main body of the phone. Unclip this (it fits like a plug and socket).
  4. You'll now have the phone in two parts,
  5. Take to the lower part and disconnect the charging port and replace it with a new one,
  6. Reverse the whole procedure for reassembly
Take care
Jun 19, 2010 | Motorola Mobility V365 Cellular Phone
My motorola l6 was not functioning the charging port....so right now i used a desktop charger? plz help
Have you tried carefully cleaning out the charging port with a soft toothbrush? If you attempt this please be very careful because the contacts in the charging port are easily damaged. Sometimes fluff and gunk can build up inside the charging port and the charger cannot make a good connection. If you do not want to attempt this you should take your phone to a reputable phone engineer or Nokia service point for repair.
May 20, 2010 | Motorola Mobility L6 Cellular Phone
My daughter's cell phone charger no longer works. I tried my charger and it still doesn't work. I think plug inside her phone is damaged. Where do I go from here?
Could be the battery.
Try putting your battery in her phone or vice versa and see if the battery will charge.
If her battery will charge in your phone, then it is the charger port on the phone but if it won't charge, then the battery needs to be replaced.
Sep 25, 2009 | LG Dare VX9700 Cell Phone
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Not charging N1100
i think the charging port might have damaged or the charging IC is gone ...
just give a try with the other charger ...
if the charging port is gone then you replace the port with the new one ...
if the charging IC is gone you must get the new one and solder it ....
just have a check after opening the handset check whether is there any loose contact inside near the charging port ...
make sure of which type of problem you have and then taking the necessary steps ..
any doubts reply me
i am always here to assist you
thank you
bye ....
Apr 10, 2008 | Nokia 1100
Sony Ericsson W710i Cellular Phone Logo
47 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
