Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
I have a Kitchenaid Professional 6 Stand- up mixer. I'm attempting to replace the Worm follower gear that drives the main planetary drive shaft, but cannot figure out how to remove the original. Please help. Thanks. I have the same problem. Can anyone tell me how to remove the retaining pin?
  • Anonymous Mar 28, 2014
    Is it threaded
    President:
  • 2,712 Answers
I would give the "accept" to bestdarngood , if I were you..He has given the bets and complete solution there...That should work, if it doesnt. the the only recourse is a service center..
Posted on Jun 28, 2008
    Master:
  • 788 Answers
Here's a good demonstation on dissasemble and greasing KitchenAid mixers. Doesn't really get to specifics on the work gear but it shows how to get to it: http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Posted on Jun 06, 2008
  • 3,037 Answers
I found some instructions for doing this that should help you out, please let me know if you get stuck as I am more than happy to help you with whatever
Be sure that you have enough room to work on this before attempting it. The Powerhead is full of grease that is very messy, so make sure that you have paper towels on hand.
Also, while taking it apart, don’t loose any screws, put them into cups or even stick them into cardboard or anything to keep them from being lost.
First thing to do is to remove the Powerhead from the stand. This requires a (#4) Phillips head screw driver to remove the four machine screws. Be sure you have the right size screw driver, or you'll ruin the screws and never get it apart.
Next, remove the chrome trim ring (drip ring) from the planetary gear housing by carefully prying it off. You should be able to pull it off by hand but be careful not to bend it.
The planetary gear housing is pinned to an intermediate drive shaft with a steel pin. You'll need to clamp the powerhead up in a vise and then drive the pin out with a center punch and mallet. Look for a pair of small holes in the center of the planetary housing, on opposite sides of the intermediate drive shaft. It doesn't matter which way you drive the pin, but don't lose the pin.
Once the pin is out, the planetary gear housing should pull free. Use a pair of screwdrivers on opposite sides of the housing and gently pried it off. Go slow, the housing is cast metal and if your are too agressive, you can bend or break it.
Once the housing is off, just set it aside. You will see the planetary ring gear. You do NOT need to remove the ring gear, but you do need to remove the 5 or 6 screws that hold it in place, as these also hold the gear housing cover to the motor housing.
So, remove these screws with a standard slotted head screwdriver. Again, be sure you use the proper sized screw driver because you do NOT want to damage the heads of these screws.
There are four additional screws visible on the bottom of the powerhead. Remove these. You should now be able to carefully remove the gear housing cover from the motor housing. It has to come STRAIGHT off, or you will bend gear shafts and damage the housing, so be careful. If it appears to be binding, be sure you have found and removed all of the screws.
Once you have this off, you will see that the housing cover you just removed has the bevel gear and the worm gear assembly attached to it. There are other gears left inside the motor housing, but I did not have to mess with any of them, so if your trouble is there, or in the electrics, you are on your own.
The worm gear assembly is a metal tower about 3 inches tall. It contains a shaft with a pair of helical cut gears; a smaller steel one that is permanently affixed to it's shaft and a larger nylon gear that is pinned to the same shaft.
The nylon gear is designed to shred if the motor is overloaded (a nylon gear is cheap, a new motor is very expensive and takes a lot of work to replace). If your mixer stalled on a heavy load of bread dough, made a nasty noise and then the beater stopped turning but it sounds like the motor was still running (Clunk whirrr Clunk whirr Clunk...) this is probably what is broken. You have two options. If you are feeling brave, you can tear down the worm gear assembly and put in a new worm gear. If you feel competent to do this, you need no instructions from me. If not, but you've gotten this far, I'd suggest that you replace the entire worm gear assembly, because it is only ten bucks more and you won't have to worry about putting the gear and it's bushings in incorrectly.
The worm gear assembly is fastened to the gear housing cover with three short machine screws. Remove the assembly and either tear it down and replace the gear, or replace the entire assembly.
Examine your worm gear. If it is deformed, but appears that all of the teeth are "there" and just bent over, you may feel ok about not replacing the grease in the gear housing. Mine had one tooth broken off, but I was able to spot it in the grease and extract it. If you are not able to account for all of the pieces of the gear, you really should replace the grease because you don't want pieces of broken gear rattling around in there. Frankly, I took a chance by NOT replacing the grease, but I will be listening to my mixer very carefully.
Put everything back together in the reverse of how you took it apart and you should be good to go.
As you reassemble, be sure that you get the powercord strain relief properly back into it's little hole, and note that the back plate of the motor housing clips into the gear housing cover, and that if this is not properly reinstialled, your speed control won't work.
The total time to dismantle the mixer and remove the worm gear was about ten minutes. The total time to reassemble was about 5 minutes. The hardest part of the job was removing the pin that held the planetary gear housing to the intermediate shaft and the one that held the worm gear to it's shaft. In both cases, you need a way to securely clamp down an awkward shape so that you can bang on it with a hammer and center punch.
  • Benjamin Patri
    Benjamin Patri Jun 06, 2008
    thanks tohttp://forum.kitchenaid.com for the steps to replace this gear
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Master:
  • 555 Answers
Check out the Kitchenaid Repair Clinic for help on this.
2 Suggested Answers
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
Posted on Aug 25, 2008
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Jun 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Removing worm follower gear in a Kitchenaid Professional 600 mixer
You need to drive the pin out with a punch. The pin should not be crimped on both ends, but could have been damaged if the gears stripped out.
Page 6 of the service manual walks you through removing the worm follower gear and dropping the planetary. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 22, 2013 | KitchenAid KP2671 Professional 6 Series...
I have a KV25GOXWW stand mixer that from what I have read here needs a new worm gear. I checked the neil crockett site for instructions and they are great BUT, my machine does not have the little scr
It actually can be a couple things1 the worm gear2 the worm follower gear3 the thrust bearing4 the transmission cover5 the bearings on the worm gear front or rear6 the planetary main gear 7 the planetary shaft gear
You will have to open up the mixer and clean each of those to check them out. On the KV25 all are easily do-able just have a large work space and a lot of paper towels. This is a very serviceable machine. let us know what else you need.
Jan 08, 2013 | KitchenAid Kitchen Aid KV25GOXWW -...
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
I have a KitchenAid Professional 600 Series 6-Quart Stand Mixer, model KP26M1XBS, which no longer works. I was mixing pretzel dough and the mixer stopped turning. I initially just thought it overheated...
Don't worry about the Worm Gear for now. You have to make sure that the Motor
is fully functional by itself: Remove the Transmission Housing Cover (4 screws) and
the two screws holding the Motor down. Lift the Motor off the Worm Gear and set it
on the side (be careful of AC voltages from the Motor and Control Assembly).
Select Stir setting and observe the motor shaft. Is the Motor running? If it is,
Select other speeds to see how the motor performs.
With the motor now fully functional, you can now check the Worm Gear Follower
for worn out/broken teeth. Remember the motor drives the Worm Gear, it then in
turn drives the Worm Gear Follower (you may have to remove the grease to see it)
The Bevel Gear sits right on top of the Follower and drives the Attachment Gear.
Jul 06, 2011 | KitchenAid Food Mixers
Mixer makes a clicking noise and beater stops turning or mixing...gear seems to be slipping...
The only part that consistently wears out is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out and becoming chipped. The clicking noises you hear are made by the Worm Gear banging on the Follower. All the teeth of the Follower are now damaged and the Planetary stops rotating.
Removal and replacing of the Worm Gear Follower is no easy task. Let me know if you need help.
(Do not try to remove the Planetary assembly by forcing it with a screwdriver. That is not how it's done.)
Jan 23, 2011 | KitchenAid KP2671 Professional 6 Series...
Agitator Shaft in Planetary
You need to carefully tap out the pin that goes through the gear and the shaft to remove it, You can find the parts list by entering your model number HERE.
Aug 23, 2008 | KitchenAid KP2671 Professional 6 Series...
I have a Kitchenaid Professional 6 Stand- up mixer. I'm attempting to replace the Worm follower gear that drives the main planetary drive shaft, but cannot figure out how to remove the original. Please...
hi
hope it helps.
May 07, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
370 people viewed this question
Top KitchenAid Food Mixers Experts
Henry  Thomas
Henry Thomas
Custom Exchange
Custom Exchange
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
