Question about Stainless Compact Steel Refrigerator - 1.7 Cubic Foot
Stain (drip mark) on front of fridge???
Stain on front of fridge door maybe lemon juice. How can we remove this on stainless steel.
    Scholar:
  • 145 Answers
We Use Debruce Polish in all our kitchens, especially cooktops and stainless steel. Debruce also works on polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff is perfect!
Posted on Aug 24, 2009
Please tell me how to get water stains off the front a stainless steel fridge. I have tried everything I can think of.
James, If really stubborn stains, you may have to use a chrome polish and buff. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cleaning Stainless Steel Appliances Cookware and More
Removing stains from stainless steel refrigerator
How to Clean Stainless Steel Appliances Easy Kitchen Cleaning Ideas That...
Coulter Cleanup Refrigerator Rejuvenation
Jun 11, 2016 | GE Profile PFS22 33" Artica French Door...
Remove discoloration from my stainless steel refridgerator
Use this suggestion with caution. Assuming it is real stainless steel (not a coated or faux finish) and you have already tried various cleaners without success.
Purchase Scotch-Brite pads for stainless steel (many automotive stores sell them for a few bucks) and lightly rub the area beng careful to ALWAYS RUB/POLISH IN A STRAIGHT LINE WITH THE "GRAIN" or brush marks to polish out the stain. Always test this on an inconspicuous area first. This also works well with stainless steel vent hoods and cook tops.
Sep 11, 2014 | Refrigerators
Corningware quart has stain on the interior bottom what do I use to remove stain
Use DeBruce Polish this Non-Toxic Odorless multi-surface cleaner works perfect. Find them at debrucepolish.com. Try on your cook tops , you will be glad you did.
DeBruce Polish Non Toxic All Metal Multi Surface Cleaner debrucepolish...
Jan 08, 2014 | KitchenAid 24 in. KUDI02IRBS Stainless...
What's a stainless steel?
Stainless steel does not stain, corrode, or rust as easily as ordinary steel (it stains less), but it is not stain-proof. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Stainless steel is 100% recyclable and is available in different forms, a stainless steel often used in knives pots and kitchen accessories.
Jul 25, 2012 | Camping, Backpacking & Hiking
If my Kitchen Aid KSF26C6XYY00 door is in fact made of stainless steel, why do fridge magnets stick to it? Ohter people I know that have stainless steel fridges say that the magnets do not stick to t
Stainless steel is a term for a family of high chromium steels, some of which do in fact stain, although they do not rust as ordinary steel does.
The more expensive 'austenitic' stainless is non-magnetic, but harder to work into product shapes. 'Martensitic' stainless is a little more prone to staining and corrosion, but easier to work with, and is magnetic. Then 'ferritic' stainless is even cheaper, but less corrosion proof, and is also magnetic.
So yes, many stainless steels are magnetic, and if the manufacturer has not used the very most corrosion proof but expensive grade, then you will see it in that way. I would not see much reason for a fridge door to be made from austenitic stainless.
Feb 17, 2012 | KitchenAid KSF26C6Xyy Side by Side...
Broiler not working and stains around gas burners
use a stain remover like hapic, or gbc and the stain will go off.
Aug 03, 2009 | Siemens HD2515U Stainless Steel Dual Fuel...
Cillit bang stainrd stainless steel cooker
Hi
The stain is probably 'etched' into the surface of the steel-- Only way is to take off the damaged layer-- A VERY fine cutting paste should do it - and as long as its very fine- you should still have the same shine!!
Jun 07, 2009 | Kitchen Ranges
Discolorations/stains on stainless steel refrigerator surface
Tried lots of suggestions to no avail. Tried a USED, dried out Scotch Brite Cook Top pad on the scrubber handle with Heavy Duty Fantastick sprayed on the pad. Scrubbed the drip marks at the bottom and wiped away to see if it was "scratching" or marri8ng the finish. Nope, but IT WAS taking the water marks off. So I did a bit more and checked again. Working great with no problems for the finish. Cleaned the whole watermark area. Rinsed of with wet cloth. Let it dry and then used my usual stainless cleaner, buffed to shine and walked away to post this. :> My refrig is an Aman too but I read other problem sites and it is common with stainless steel refrigs
Feb 26, 2009 | Refrigerators
Fingerprint stains on stainless steel fridge doors
going with the grain( s/s has grain just like wood product) try cleaning with a stainles steel cleanlingcloth and some wd40, this will remove any defect in th metal go with the grain not across you will leave rub marks if going avcross t he grain!!
Feb 12, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Stainless Compact Steel Refrigerator - 1.7 Cubic Foot Logo
174 people viewed this question
Top Stainless Refrigerators Experts
Dan Webster
Dan Webster
billconfused
Are you a Stainless Refrigerator Expert? Answer questions, earn points and help others
