Question about Canon PIXMA MP780 All-In-One InkJet Printer
Line down the middle of the page
I have a Canon Pixma MP780. I have cleaned the glass on it multiple times. No matter how clean it is there is a line that goes right down the center of my paper. Its a light black almost grey color. It just started doing this about 2 weeks ago. I think it has something to do with our carpets being pulled up and dust getting into it. There is dust under the smaller glass area that I can't clean.
Can anyone give me a solution.
  • Nauticalse Jun 10, 2008
    Yes it is only on scanning and copying not when we actually print out something from the computer.
  • Daddie0 May 11, 2010
    I am assuming the line is on scanning/copying?
  • 390 Answers
SOURCE: canon pixma mp780 - vertical line on printing
There are a number of issues that cause vertical lines in printing. If you have cleaned all the glass panels and roller,the next primary cause is a blocked printhead but people have success cleaning and refilling cartidges as I do. How old is the cartridge, as they do eventually wear out due to the printhead points wearing out(hold the cartridge to the light and look on the printhead, do the points appear scratched or white dots? This indicates replacement. How much ink is left? When black ink is low but not low enough to show a message, sometimes vertical lines can appear. Try checking ink status, or try refilling ink if you know how. If this issue reoccurs with a new cartridge it more than likely could be the printers printhead and not the cartridge. Cartridges can become clogged if not printed with for a while. Try standing the cartridge on newspaper for a while. Blot it dry and retry it.
Posted on Aug 09, 2007
SOURCE: paper jam light constantly on.
The suggestion with the heavy stock paper worked. I used a vanilla folder but this was not heavy enough so I simply folded it in half. I had the problem where it would feed 1 sheet of paper in the auto sheet feeder upon starting the printer up. This is unusual in itself. The single sheet of paper would go through normally. But with the vanilla folder, as it was going through, I heard a loud sound like a contraption somewhere was being reset or dislodged or relodged or relocated from some stuck position. After the sound, the green light came on no problem and it all worked. Try something not so heavy like a vanilla folder that has been trimmed down. Then fold it. You might have to hold it up against the black roller wheel to get it to engage the roller wheel when you turn the printer on. Hope this helps.
Posted on Aug 25, 2007
  • 518 Answers
SOURCE: canon pixma mp780 printing problem
Try replacing the color cart. with a NEW one.
Hope that helps...
Geno
Posted on Mar 26, 2008
SOURCE: software for canon pixma mp780
i need the software for a canon pixma mp780 printer thank you
Posted on Nov 03, 2008
  • 909 Answers
SOURCE: Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
Posted on May 03, 2009
Every time I try to batch scanning on my Pixma MP530 I get a vertical line running through the page. I've cleaned the platen glass, the inner side of the document cover, the transparent sheet (I even...
When using the ADF to scan multiple document the scanner assembly stay stationary and the paper is fed across it. Where the scanner parks for this there is something between the scanner and the document, likely on the glass. Often there is a small strip of glass on one end of the scanner bed. Clean here if there is one, otherwise look around and I'm sure you'll find it. Remember, never spray cleaning solutions directly onto the glass, always onto a cloth or towel first. The scanner has a calibration strip that can be damaged otherwise.
Feb 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
When i scan on my Canon Pixma MP780 printer i get a red line down
This is what the service manual says:
(1) Clean the Document glass.
(2) Check the connection
between the contact sensor
and SPCNT board (JCCD1).
(3) Replace the SCANNER
unit.
(4) Replace the SPCNT board
***’y.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
On my Canon Pixma MP780 a vertical line appears on copies made using ADF
I tried the other solutions listed here - and no luck. After cleaning the inside of the ADF, like the manual suggested - no change. How are you supposed to do that anyway? Deep cleaning the inside of the machine also has nothing to do with it.
I finally figured out why things that I copied with the ADF had lines/marks on them, but those placed directly on the platen (big glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Nov 27, 2007 | Canon PIXMA MP780 All-In-One InkJet...
MP780 photocopies made using ADF have a line which obscures content
I tried the other solutions listed her - and no luck. After cleaning the ADF rollers, like the manual suggested - no change.
I finally figured out why things that I coped with the ADF had lines/marks on them, but those placed directly on the platen (glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Nov 24, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Line shows up down right side of page that was copied or Faxed
your ink wel needs cleaning, do some deep cleaning and if that dont work take your ink well out and clean it manually
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
Nov 11, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Toshiba dp 2570 "dirty copies"
Have you cleaned the insides of the printer? If you have then check the fuser assembly . Thats the part that heats up. It probably has ink on it and is transferring it to the paper. If you cannot clean the fuser roller you will have to replace it or get someone who can.
Aug 29, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Black Line printing on copies
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Dec 04, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Verical line(s) problem with canon mp780
Hi Nick, It's ONLY when you copy? I start by cleaning the platen glass. Wipe the Platen Glass with a clean, soft, lint-free cloth moistened with water. Then wipe with a clean, soft, dry, lint-free cloth making sure not to leave any residue, especially on the Platen Glass. If you have trouble getting the scanning area clean, wipe with diluted mild detergent (for dish washing). Do the same thing for the white area under the platen lid. If this does not resolve the problem let me know. His Dudeness
Nov 15, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
