Question about Brother MFC 9700 All-In-One Laser Printer
Jammed paper deeper inside of machine
Hello, please advise. I must have some jammed paper deeper inside the machine. I have opened all doors and taken out the toner cartridge and see nothing regarding paper but the piece I pulled out originally from the tray area was not whole so I know some paper remains.
Thanks, Mary
  • Quetzal Jun 12, 2008
    Hello, I take it the fuser is the drum? I've been all over this machine as much as possible without taking screws out. How do you remove the fuser? I am unable to use the machine at all as "jammed papaer" is the only comment.
  • 3,037 Answers
Take out the drawers first and see if you can find any paper from that area. Let me know how this goes.
you can also try manually spinning the rollers to see if anything will come out.
Posted on Jun 06, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are still having trouble getting to the jammed paper, let me know, otherwise
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 13, 2008
    You see the access door in the back where you would remove a jam? That
    is the back side of the fuser unit. You'll have to take the scanner top
    off and the other back panels to unplug the scanner and controls....the
    sides, the laser assembly, other things... and finally you'll have to
    disassemble the fuser in order to remove it and get access to the
    sensor arm and to the piece of paper still assumed to be jammed in the machine, if the sensor is broken, it may have to be replaced.
    Just look and remember where all the parts go.
    Be bold... but don't yank on anything. Take your time. No sledge hammers are needed.
    If the sensor arm is broken, you
    can't just remove the broken sensor arm. The printer needs it to know
    where the paper is during its travel. It will need to be fixed or
    'engineered' back to a functioning form.
    Good Luck
  • Benjamin Patri
    Benjamin Patri Jun 14, 2008
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    Master:
  • 555 Answers
Try removing the fuser to check inside of it and behind it for paper scraps. (Note: the fuser gets extremely hot, so make sure your printer is unplugged and cool before touching the fuser!)
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
WILL NOT PICK PAPER SAYS PAPER JAM
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Aug 17, 2010 | Dell 924 All-in-One InkJet Printer
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
Paper jam in fax how do I clear?
folow the instruction
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
    Printer light is on even when paper is in machine and wont print
    Did you check the back cover for paper jam?
    Still have some paper jam in your machine.
    Be sure you openned all cover, paper tray and pull out the drum to check.
    May 29, 2009 | Brother HL-2030 Laser Printer
    Paper jam!!
    Please perform the below steps.
    1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    put the cables back and switch on
    Aug 25, 2008 | Brother HL-2070N Laser Printer
    How to fix paper jam Epson CX3650?
    2.
    3.
    4.
    5.
    6.
    Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
    7.
    Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    CREDITS: nanicool
    IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
    I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
    THANK YOU
    REGARDS
    SWEET RASCAL
    Jun 28, 2008 | Epson AcuLaser C3000 Printer
    Printer
    2.
    3.
    4.
    5.
    6.
    7.
    Jun 03, 2008 | Office Equipment & Supplies
    Brother MFC 9700 All-In-One Laser Printer Logo
    121 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
