Question about Danby DCD5505W Electric Dryer
Is it dead
My Danby front load with model number DCD5505W-1 want tumble. Can you in struct me on how to fix it?
    Novelist:
  • 97 Answers
This could be caused by different things: Does it make a motor running sound when you try to dry, but the basket won't turn? If so, it's probably a broken or jumped belt, which would require a fairly extensive disassembly to repair.
But It can also be caused by the "door closed" interlock switch, located somewhere in the door frame area, usually activated by a pin-like or tab protrusion on the inside door facing. Make sure the door is fully closed. If still no go, try and locate the switch and actuate it externally with a toothpick/straw (or anything that approximates the protrusion on the door that normally works it) with the door open and try the start button again. Still no joy, jumper the switch terminals to bypass the switch and try again. If it goes now, then it is a bad door switch.
It could also be a bad start switch, bad motor, or bad connection in the wiring to the switches, timer, and motor. All of the above require some disassembly to get at the components, and a Volt-Ohm Meter (VOM) woul be invaluable in locating the fault.
Dryers are fairly simple devices compared to other things, but the addition of programmed features has made them a little more complex, but once the component functions ae understood, they are not difficult to diagnose and hopefully repair. The biggest obstacle is learning how and what order to disassemble to access the parts,and then get it back together again in a proper fashion.
Hoe this shed some light on your problem and gives you some ideas to try. Good luck!
Posted on Jun 07, 2008
Danby dryer dcd5505w-1
You probably have a broken drive belt.
Feb 17, 2013 | Danby Dryers
Running with no heat
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 30, 2009 | Danby DCD5505W Electric Dryer
Dryer will not tumble
you need to turn your dryer up side down, remove the bolt or screw then remove the cover, there you can see the belt, see if it mis-alligned or detached, or if it is cut the just get the part number of the belt and post it here
Jul 29, 2009 | Danby DCD5505W Electric Dryer
Danby dryer has stopped spinning
Here are the Danbyinstructions:
INSTRUCTIONS TO CHANGEDRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF
THE FRONT THAT GO FROM BOTTOM UP. REMOVETHE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK ANDLIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THATHOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREWFROM THE CENTER
BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACHSIDE AT THE
TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWSAROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVETHE 2 SCREWS ON EACH SIDE OF THE
INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THEBELT, IDLER, AND
MOTOR MOUNTS. THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THEBLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Feb 15, 2009 | Danby DCD5505W Electric Dryer
How do I get the top off the dryer or do I have to take front off to get to the loose connection behind the knobs. O r were can I find the fuses for this dryer danby front load
on 9 out 10 front loaders there is 2-3 screws on back of top, take those out and slide top back and take off.
if your model has a fuse it will be a thrmo-fuse on the blower housing and it will have 2 wires connected to it / larry
Nov 29, 2008 | Danby DCD5505W Electric Dryer
Dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Oct 30, 2008 | Danby DCD5505W Electric Dryer
Hello....
I needed to replace my belt. I called the Danby Customer Service number 1-800-263-2629. I called early in the morning and got straight through. I received wonderful, prompt friendly service.
The belt cost $25.19 plus postage and handling.
Joe
Jan 16, 2008 | Danby DCD5505W Electric Dryer
Door Handle Broken
yes contact your local appliance dealer or if you have the manuals that came with this dryer contact the manufactuer by the listing on thier literature.
Or do a web seach LIke :DANBY DCD5505W DRYER PARTS
Jan 15, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505W Electric Dryer Logo
159 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
