Question about Samsung SF-4500 Plain Paper Thermal Fax
Samsung SF 1600 Fax
The lights on the fax machine keep blinking on and off. Because of this, none of the buttons work. Not even the dial tone gets through the handset. Can anyone tell me how to fix this problem? I will greatly appreciate it.
Thanks!
  • 21 Answers
SOURCE: No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Posted on Oct 05, 2007
SOURCE: Samsung SF-3100 Fax Windows XP drivers for pc
the star button push hard and operae
Posted on Oct 13, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
Posted on Nov 14, 2007
printerman40
  • 170 Answers
I believe that with this model there are 2 places to insert a phone line and you may have them backwards, also, it could be a bad phone cord that your using... check these easy things first...
Posted on May 07, 2008
leroyal
  • 2120 Answers
SOURCE: Samsung Laser Fax Machine SF 5100 Manual
What is your question?
Posted on Sep 05, 2008
Fax to 1-815-346-2473 on my SF 650 machine?
Dear
first check the no 1-815-346-2473 with your telephone company. In the said model there is a handset. do -lift hand set here the companys dial tone dial the required tel. no. here the Rx.tone from the other fax machine connected. If its working definitely your fax machine will transmit the data.
If the fax machine has connected behind EPABX, it has unique no. to dial out side of the epabx. In that case contact your EPABX provider to program the fax machine.
Thanks.
Dec 18, 2014 | Samsung SF-650 Laser Fax Machine
No dialing
see if the tel line is in the black plug. and see if you got a dial tone. if not test line whit other phone. if no tone. fone your provider.
Dec 19, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Have a dialing tone but will not send a fax,it says" job waiting" and will not clear by turning off power
Take the power out. hold the red button in and put the power back. this will reset the unit
May 24, 2011 | Samsung SF-5100 Plain Paper Laser Fax
We cannot send or receive a fax - no settings were changed
If you can not send or receive faxes the machine most likely is not getting a dial tone.
Start by unplugging the telephone cable from the machine and from the wall jack and then plug it back in. Make sure you are reconnecting the telephone cable to the correct jack on the fax machine.
If this does not help, try using a different telephone cable or try connecting to a different wall jack.
If there is still no dial tone and the machine does not work, I recommend trying it in a completely different location. If this still does not work then you can safely say that the machine is broken.
Thanks,
Pat
Nov 08, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
Sf-5100 issue
Kindly check the setup. Before anything refer to manual and check that you are getting a dial tone for sending in a telephone set.
Best Regards
Rafique
Mar 27, 2008 | Samsung SF-5100 Plain Paper Laser Fax
SF-515 does not dial anymore
Hi there try this press menu then using the arrow keys go into machine settings I think if not you are looking for line type. Once in the make sure it is set to tone.
Once you have done this come out and try if this doesn't work then the control panel maybe faulty and you could take it apart and clean the number pad keys and make sure that the buttons move freely.
If they do cleanup and put back together and check machine if it still doesn't work then the panel will more than likely need replacing.
Thanks J
Nov 14, 2007 | Samsung SF-515 Plain Paper Laser Fax
Samsung SF-4500 Plain Paper Thermal Fax Logo
737 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
