Question about Frigidaire 14 Cycle Tumble Action Washer
Runs Cold no heat ? Tumble Dryer
Works ok but no heat,only 2 years old,hotpoint want £90 just to look.Thermostat or heating element? Shame to bin it!
Thanks in advance.
Hotpoint VTD00P
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Free tumbledryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
My hotpoint TDC30 dryer is cutting out after 3 mins ,the drum is warm inside and wont restart till its cold inside the drum
Hi joanne balla...
Sounds like the cyclic thermostat, thermostat, fuse (differnet names for the same part)..is faulty...replace it.
You will have to remove the back from the machine, look for the air tube going to the vent of your dryer and located on it will be the thermostat/s.
To test it, remove the wires fromthe two terminals and tape them together, then try running your dryer again and if it runs and heats ok then replace the cyclic thermostat/fuse.
Go to the following webpage to see the thermostat
Please take time to rate me
http://www.espares.co.uk/parts/tumble-dryers/thermostats/hotpoint/p/1587/808
Sep 13, 2011 | Hotpoint Dryers
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 12, 2010 | Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
Hotpoint ctd00G will not heat up
This is most likely the thermostat switch or possibly the heating element itself.
One or the other is likely needing replacement.
If you are competent at electrical repairs, and have a test meter; Unplug and move to allow access.
Undo rear top screws and remove lid.
Heating element is usualy on top. Disconnect leads and check continuity of switches and element.
Replace switches with similar if either are open circuit. Available as spares from online parts centres.
Heating element should read in the low Ohms - around 20 - 35 Ohms if Ok, otherwise replace.
ONLY ATTEMPT REPAIRS IF COMPETENT (I have to say that)
Sep 23, 2009 | Dryers
Hotpoint CTD40P tumble dryer only runs cold.
hello check the heat sensors first good luck
shaun
Aug 04, 2009 | Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
205 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
