Question about Whirlpool Dryers
I am trying to figure out how the cabinet to my dryer comes apart so I will be able to replace the heating element.
  • 5,911 Answers
If your dryer has the lint screen on top of the cabinet, the heating circuits are located in the rear of the dryer. They can be accessed by removing the rear panel.
If your dryer has the lint screen in the door, the heating circuits are located under the dryer drum. They can be accessed by removing the lower panel under the dryer door. The panel comes off by inserting a putty knife in the seam, about 2 inches in on each side and depressing the release tabs. If this is a Kenmore Elite or Whirlpool Duet model, the lower panel comes off by removing the screws under the bottom edge of the lower panel.
If there is no removable panel, the entire front casing needs to come off. This is accomplished by lifting the dryer top to gain access to the screws that hold the front panel place. Use care not damage the door switch connector(s) in the process.
Lifting the top panel can be accomplished in the following ways (depending on model):
1. Grab the sides of the top panel and pull towards you while lifting up.
2. Lift the operator console first and then remove the three screws holding the top panel in place. Once the screws are removed the panel slides forward, then off.
I hope this is helpful to you. If you experience problems, please post back with your model number, so I can narow down which dryer configuration you have. Good Luck.
Posted on Jun 06, 2008
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Tip
    How to Replace Heating Element from a Maytag Dryer?
    The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
    2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
    3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
    4) The heating element is located in the cabinet.
    5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
    6) Locate the heating element cabinet and remove the screws holding the cabinet.
    7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
    8) Remove the connector carefully from heating element with the help of needle nose plier.
    9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
    10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
    11) Remove the old heating element and insert the new heating element.
    12) Connect all the wires as it were connected before.
    13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
    This will help. Thanks.
    on Mar 20, 2010 | Dryers
    Kenmore 110 dryer.. wife says its taking way too long to dry clothes.. it is heating.. wondering about airfflow. cleaned everything.. can't figure out how the air gets INTO the dryer cabinet.. I...
    inside the drum there are holes that may be clogged, I would disconnect the vent tube run a load of laundry. If it dryers then I would clean the vent tube, if not then I would take apart the dryer and clean out all the lint, and this should fix the problem. Good Luck Tim
    Feb 05, 2011 | Kenmore Dryers
    My maytag electric dryer wont heat up
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
    My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
    My dryer will run, but will not heat.
    Hello there
    Heating Element
    Thermal Fuse
    Thermostat
    Timer motor
    Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
    My tumble dryers not drying my clothes, i've had it coming up 6 years
    Proper Voltage
    Jan 22, 2010 | Whirlpool LER5636P Electric Dryer
    Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
    Hello there:
    please try this
    Proper Voltage
    Jan 19, 2010 | Dryers
    Maytag dryer model # LDG8000AAW dryer comes on and the burner lifgts up but dryer dosen't get hot.
    Hello there:
    please try each step of this guide i have provided for you
    Proper Voltage
    Whirlpool dryer will not heat
    Hello there:
    There are 5 things that would not make the dryer heat up i will post you them here ok
    Jan 17, 2010 | Dryers
    Dryers Logo
    120 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
