Question about Nintendo DS Console
Charge problem my ds just stopped charging the orange light does not come on at all it started 4 weeks after i replaced the top screen both the charger and the battory is still good its driving me nuts HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 2,794 Answers
Sounds like it needs to be repaired. Could be a faulty power supply in the DS.
Posted on Jun 10, 2008
DS charging..light stays orange...
It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
Jul 06, 2013 | Nintendo DS Lite Console
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
DS Charging Diffuculties
( times out of 10 here its the battery if by replacing the battery it still does not charge you got a bad charging unit inside the DS and your repair bill will be under $75 bucks to replace the chargin element inside.
Like my advice please accept and rate it today. We accept all postive answer ratings , Thanks.
Oct 09, 2009 | Nintendo DS Lite Console
DS is stuck in charge mode when plugged in.
Your DS may have a problem reading the battery gauge, and the DS will only let the charger do its thing for a period of time. Then, if it is still connected, it may burst more charge in. This means that your DS is acting up, and your battery may have a rare (and not harmful to the DS) malfunction.
Jun 10, 2009 | Nintendo DS Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
I have a major problem!!!!!!!! Please try to help!!!!!!!!:((
you will need to replace the upper lcd screen, when the power light came off it caused the top and bottom shell to shift back and forth causing the lcd ribbon to become damaged, the flash you see is the power from the botton trying to make it's way to the top, send to ebay ed-kar-3 for $38.00 to fix
Oct 18, 2008 | Nintendo DS Console
Ds not working after 3 weeks not being charged
that means it must be finished charging or check out a solution on lights not working
Jun 01, 2008 | Nintendo DS Lite - Onyx
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Hey everyone, not sure if this will work for everyone, but its worth a shot.  my problem was identical to all the others here, a flash of orange and then nothing.
i thought perhaps those little metal contacts on the battery and the ds had build up a little corrosion, interrupting the charge.  so, i took some rubbing alcohol and q-tips and gently scrubbed them clean, both on the battery AND the ds side.
After this, my ds has worked flawlessly.  Hope it's the same for you!
Feb 06, 2008 | Nintendo DS Lite Console
Not charging
Quite honestly...
I know that this is probably not the answer you guys want to hear about this issue...
You're going to have to contact Nintendo and make good on your warranty on this one. Just tell them that the unit is no longer charging and that you 'don't know why'. They should have no real problem replacing it for you.
This is most likely an internal electronics issue that no expert here is going to be able to advise on.
Unfortunately the internet still isn't good enough that we can do solder jobs over our internet connections. :P
=THIS IS NOT A PROPOSED FIX. DO NOT RATE ME FOR IT=
Otherwise, if you wish to persist in trying to fix your problem, the only thing that I can tell you is to either try using someone else's charger adapter, buy a new adapter OR use an adapter that works and hold it at different positions in the DS Lite to see if any position will charge it. If you are succesful at charging it in this manner then the port you plug the charger into may be loosened.
===DO NOT RATE ME FOR THIS POST. IF YOU GIVE ME A POOR RATING FOR THIS POST I WILL DISPUTE IT WITH THE FIXYA STAFF AND ASK THAT IT BE REMOVED. I AM NOT ATTEMPTING TO SOLVE YOUR PROBLEM BUT AM GIVING YOU ADVICE ON WHAT YOUR BEST BET IS. I WILL however accept a GOOD rating if it is given - naturally. LOL===
Regards,
Cyryl
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
