Question about Konica Minolta magicolor 2400 Laser Printer
Black line on right side of prints
Hi MagicDave,
When I print a faded black line about 1" wide appears on the right side of the page and down the entire length. Upon inspection inside the printer, the green drum has toner dust on the right side. I can clean this but when I print another page it comes right back.
    Champion:
  • 214 Answers
The drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Posted on Jun 19, 2008
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
OkiC5200 has an inch wide faded print line down the left side
It might be a dirty led assembly. The leds hang down from the top when it is opened.
May 03, 2009 | OKI C5200n Laser Printer
Black streaks on printout
Your fuser is worn out. Needs to be replaced.
Mar 27, 2008 | HP LaserJet 5p Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
820 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
