Question about Kodak EasyShare Z650 Digital Camera
Kodak Z650 LCD is black
We have a Z650 that was working perfectly until we downloaded pictures one time a few weeks ago. In the middle of the download, there was an error and Easy Share said it could not delete the picture. After that, the LCD screen is totally black. I have remved the memory card and replaced the battery. I can still take great pictures, but can't see anything through the view finder or on the LCD. When I download pictures now, the LCD works to show the progressso I don't think it is bad.
    Genius:
  • 1,673 Answers
Check to see if there is a battery save mode for the viewfinder. Check the instruction manual for this.
It is also possible that the drive circuit for the LCD display has a fault. It was simply coincidential that it went bad while you were transfering pictures.
Jerry G.
Posted on Jun 29, 2008
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
Cannot download pictures from my Z650 camera to my computer
Kodak EasyShare Z650 Digital Camera has its own internal memory and its sd card also.Now you can connect the camera with the computer with the data cable .Now you can see the new hardware found and the open the camera images in computer .
Aug 30, 2010 | Kodak EasyShare Z650 Digital Camera
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
My Kodak Z650 camera just won't switch ON. I used the camera a few weeks ago and it was working fine and after using it, I removed the battery and packed it away for next use. The next time i tried using...
Hi there Make sure the new batteries are fully charged before used. After that remove the memory card & try to power on. If its not ON then i suggest you remove the battery & check the that place for any sulfur layer( green colored ) are there or not. Just clean that place & put the camera in sun light for 10 minutes. Because some time moisture make short the circuit board & that's why camera would not turn on. If its a moisture problem then after those operation it will start working. But if your camera power supply converter are damaged then its not possible to repair at home. So go for all these basic treatment & after that if you not success then i suggest you please visit Kodak service center for replacement or repair. Thanks.
Apr 02, 2010 | Kodak EasyShare Z650 Digital Camera
Kodak easyshare z650 cracked lcd screen. Is it
Out of Warranty the repair of this model for this fault is about 88 pounds + shipping to the repair centre.
KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 08, 2009 | Kodak EasyShare Z650 Digital Camera
LCD/EVF screen come on but is "snowy"
The problem is the lens is not opening, If you look into the lens you can see it is closed. This will require a trip to the repair shop.
Aug 16, 2008 | Kodak EasyShare Z650 Digital Camera
Lines in images
Color lines in the LCD display is caused by certain type of light connections. If you get all the time when you turn on the camera then the LCD panel is bad, would need to be replaced. Black lines in printed printed pictures from your printer or the Kodak dock station printer? If that's the case, then the transfer rollers are dirty and would need to checked or replaced. Also drivers could do this also. Report the problem to Kodak Live Chat Online Tech Rep or called on the LAN line (phone).
Jun 25, 2008 | Kodak EasyShare M853 Digital Camera
Veew Videos/Pictures from Kodak Z650 Camera
import your camera files into your hard drive using the proprietary software that came with your camera. Then view on the monitor using same proprietary software
Nov 30, 2007 | Digimate DGL2700 27 in. LCD Television
Kodak EasyShare Z650 Digital Camera Logo
102 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
