Status code H 4. All indicator lights on, but nothing responds. Turned off and unplugged several times for at least 10 seconds. Still get "H 4" message. .
Try this : press clear intrupt clear intrupt buttons in this sequence and after that 14 start. if the fuser is ok machine will run if you still get the code its fuser needs repair. for more support write to [email protected]
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds
<b>Amana:<br /></b>
<ol>
<li>Press and hold the <b>dispenser lock</b> and <b>auto light</b>
buttons on the dispenser for 4 seconds until the filter
status indicator begins to flash, then release the buttons.</li></ol>or<br />
<ol>
<li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br />
<ol>
<li>After replacing the water filter, press and hold the Reset Filter pad
for 3 seconds. The Order and Replace indicator lights will blink and
then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br />
<ol>
<li>Press firmly and hold start button for 5 to 10 seconds.</li>
<li>Four
bars will appear in the display, one after the other, and flash. Do not
release the start button until the 4 bars appear and start to flash. If
you have difficulty pressing the start button, a capped ballpoint pen
may be used to press the button down.</li>
<li>A small flashing dot in the lower right corner shows the indicator is working.</li>
<li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li>
<li>After
2 months, when all bars have disappeared, an arrow will flash at the
top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b>
<ol>
<li>Press and hold the <b>reset </b>button on the dispenser
until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b>
<ol>
<li><b>P</b>ress and hold the <b>reset water filter</b> button
on the dispenser for 3 seconds.</li></ol>or<br />
<ol>
<li>
Press the reset button on the dispenser for 4 to 8 seconds then release.
</li></ol><b>Hotpoint:<br />
</b>
<ol>
<b>Jenn-Air:<br />
</b>
<ol>
<li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b>
<ol>
<li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br />
<ol>
<li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br />
</b>
<ol>
<li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b>
<br />
<ol>
<li>
Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol>
<b>Maytag:<br /></b>
<ol>
<li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br />
<ol>
<li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br />
</b>
<ol>
<li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press
these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li>
<li>Release the buttons and repeat the same step one more time. The water
filter indicator light should turn green.</li></ol>or<br />
<ol>
<li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br />
<ol>
<li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i>
buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br />
<ol>
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys) Press "C" then the far left key (exposure mode) then the "C" key then the far left again. So in other words C, far left, C, far left If done correctly the display should go blank. Now key in 14 as if you were going to make 14 copies. Now press the print button. The machine should reset and the code should be gone. 9 times out of 10 this is a false code that pops up due to power surges or noise. If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Give this a try , if it continues you will have to replace the fuser.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
Turn the power off.
Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
Locate the Auto Button the lower left corner of the Control Panel.
Turn the power back on.
Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
Program the copier as if you were going to make 14 copies.
Press the green [Start] button to store the reset code. The copier will return to the ready position.
