Question about Sharp AR-BC260 Color Copier
Sharp AR-BC260 greetings. i hope you can help and appreciate any advice. ar bc260 is printing pages but then page is getting stuck at fuser unit. you posted a reply for a different unit and we tried to take a look based on that info but i believe the fuser is different. any suggestions? thanks in advance...
  • Sharp Master
  • 2,794 Answers
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Posted on Jun 11, 2008
Any chance on getting the AR-BC260 to work with Windows 7?
This is more a workaround than a permanent solution, but I've shared the printer from an XPx64 machine, and then the Win7x64 machines in the office can print through the XPx64 machine. It's a bit glitchy, but it's better than nothing.
May 15, 2010 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Sharp AR BC260 color printing Lots of ghost lines in color prints
depends on what is the problem with it? if it's only toner on it, let it cool and clean w soap and water rag, then wipe clean. I suspect that it is most likely scratched and the coating on the fuser is missing, it should be a shiny smooth surface.
Nov 19, 2008 | Sharp AR-BC260 Color Copier
Printer constantly paused during printing
Is Post Script Key in the Mahcine? (PS must be intalled on the machine)
Do you have the Correct Driver
www.sharpusa.com
Aug 08, 2008 | Sharp AR-BC260 Color Copier
Sharp arc 262
Turn off machine, open drawer where fuser unit is and gently pull out the jammed paper. You may have to replace the fuser unit.
May 27, 2008 | Sharp AR-BC260 Color Copier
Sharp arc 262
Open the Left side door and remove the fuser unit by unscrewing the large green wheel located under the frame on the left side door below the fuser unit. Lift the fuser unit using the handles front and rear sides. (be careful it is very hot). Set the fuser unit on a table or counter or desk. Look carefully at the left side, as it sits in the machine, near the middle. You should see a actuator for a sensor. Make sure both ends of the arm are in the holes where they shoud be. If it is out of place, put it back into place and carefully place the fuser unit back in the machine. Secure the fuser back in the left door and close the door.
Sharp ar-bc260
change the transfer belt, and drums, suggest a whole Preventive Maint.. , part broken in tray 1, that is not enough detail..
May 16, 2008 | Sharp AR-BC260 Color Copier
Printing
No, but go to www.sharpusa.com and search in the upper right corner search box for print driver. It will come up with a "click here to download drivers for your MFP". Select the AR-BC260, and you windows version and dowload the PCL 5C print driver. Run the downloaded file. You need to know the IP address of the copier first.
Oct 22, 2007 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 Color Copier Logo
117 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
