Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
IFC on Trane furnace
Trane literature says when the thermostat is set to 'on', the furnace fan will operate for the cost of a 60 watt bulb. I know four Trane owners (units less than 2 years old) and only one of the four operates at that level....the rest are operating at approximately 350 watts and it is cost prohibitave to run. I want to get full benefit of my electronic filter. Local service techs say they don't have a solution...Trane headquarter techs say it is in the IFC. They did not say if it can be tweaked.
If the furnace is a vairable speed furnace you have to make sure that all you dip switches are in the correct position on the lower furnace door there will be a label that gives you info on how to boost cfm and other info if you look at this label you will find a comfort R setting this is what you want to set to get the lowest fan setting but it does have to be a vairable moter
Posted on Feb 23, 2009
  • 56 Answers
If the manufacture says it is the IFC then you should have the IFC checked by the company who installed it if it is under warranty still
Posted on Feb 16, 2009
4 Suggested Answers
JohnSc
  • 21 Answers
SOURCE: Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Posted on Feb 11, 2008
SOURCE: Amana Furnace runs shuts down then relights
flame rod sensor
Posted on Jan 13, 2009
  • 189 Answers
SOURCE: Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Posted on Mar 08, 2009
Furnace mounted humidifier when set thermostat to operate automatically it kicks the solenoid on but when the furnace shuts off the solenoid stays on When I turn it off at the thermostat it shuts off
Without knowing the exact humidifier and how it's wired one can only guess.
There are many different ways to wire a humidifier, one method involves the use of a current sensing relay monitoring the operation of the furnace fan motor. Another uses the HUM terminals on the furnace to control the humidifier.
Has the humidifier ever worked properly? If so, a component has failed. If not, it wired incorrectly and you need to refer back to your installation manual.
Oct 28, 2016 | Humidifiers
Dry house with furnace mounted humdifier
Is the furnace fan set on auto or on. You will get better humidity if you keep the fan on. It won't add much to your electric bill because many of the newer furnaces operate the fan on DC voltage. Try it!
Jan 16, 2010 | Aprilaire 700 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Good Luck
HVAC Teacher
Mar 08, 2009 | Honeywell Power Humidifier: Furnace...
Hooking up a used 550 to a new 80% trane UD-R9V,
In this situatioin you'll eed a second transformer 110volt to 24 volt to relay from w to common to operate only when furnace being called for.
Feb 07, 2009 | Aprilaire 550 Humidifier
Looks like my humidistat calls for coil fan and for furnace heat
It sounds like the humidifier may be improperly wired.
It's hard to solve without checking the wiring, but it seems like the humidistat is wired so that as the dial is advanced, it incorrectly turns on the fan, or furnace, or both.  The contacts of the humidistat should be wired so that they turn on the solenoid only.  Also, the power to the humidistat, to turn on the solenoid, should come on only when the fan is on.
Hope this helps!
Jan 03, 2009 | Aprilaire 550 Humidifier
Humidifier won't turn on with furnace fan set to Auto.
There is a devise called a current sensing relay (a little black box that hangs on a blower motor wire that senses current from that wire) If you have such a devise it should hang from the white (common) wire. Loop the wire through twice.
Nov 23, 2008 | Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
Nov 10, 2008 | Aprilaire 600 Humidifier
Furnace
I would guess from the info provided that you only have two wires going to your thermostat which would explain why the fan switch doesn't work on the thermostat. You can bypass the thermostat as a first step in troubleshooting. After that it depends on the type of furnace, standing pilot or electronic ignition...
Nov 29, 2007 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
1,320 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
