Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Shutter action Hi Is there anyway of finding out how many shutter actions my Nikon d40 has performed? I've trawelled the user manual and have found nothing
    Problem Solver:
  • 16 Answers
You will need a 3rd party software software to check the number of Shutter actions/release. Check this site.
Posted on Jun 08, 2008
I have a Nikon D40 and when it's in M and S mode the shutter stays open for too long and my pictures come out completely white.
What shutter speed(s) are you using? What happens when you use a faster shutter speed? In the S and M modes you are responsible for setting the shutter speed, and you can set it to anything within the camera's range.
Aug 28, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Slow sync flash - nikon d40
Set the exposure mode to Manual (M) or Shutter-priority (S) and specify the shutter speed yourself. You'll have to set it sufficiently slow in order to see any difference between front- and rear-curtain.
Mar 02, 2010 | Nikon D40 Digital Camera
D40 Nikon
i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
Feb 21, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Error message on display
you might have a stuck shutter. have it checked by nikon..
Jan 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Blurry action pictures!
This Powershot A590 camera has a Kids and Pets mode that may help. If that doesn't work, you need to set your camera to Shutter Priority (TV) mode on the dial. Then you use the arrows to increase or decrease the shutter speed setting. Depending on the sport/action, your shutter may need to be 1/400 up to 1/1000 or higher.
You may find you don't have enough light to get a fast shutter speed at the standard ISO, so you may also need to increase the ISO. Only increase it as much as needed to get your shots, and don't forget to return it to a lower ISO when you are done. You set the ISO from the Func/Set button menu.
You will have a relatively shallow area of focus (called depth of field) unless you have a LOT of light and are using a relatively slower shutter (e.g. 1/400 vs 1/1000). So be sure to keep the center of the focus on the player you are shooting.
Check your user manual for instructions on how to change to the AV mode and how to set the ISO. If you don't have your user manual, you can download it here, from Canon.
Finally, this type of camera tends to have a lot of "shutter lag" between when you press the shutter and when it takes the photo. You need to plan ahead and press the shutter in advance of the "peak action" when you want to capture the photo.
Dec 17, 2008 | Canon PowerShot SX100 IS Digital Camera
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 shutter is not releasing err is releasing butten again but same prob
I had the same problem. I sent my camera to the Nikon Service Center. They fixed it within three days. They actually replaced the whole aperture frame. FREE OF CHARGE AS LONG WITHIN THE WARRANTY PERIOD.
Jan 22, 2008 | Nikon D40x Digital Camera
Faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
Nov 01, 2007 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
