Question about Creative Labs ZEN V Plus MP3 Player
HOW TO RECONNECT LCD SCREEN ON V PLUS?
The player wouldnt recharge. tried reset and recovery and stinky tech support at zen... went on youtube and saw someone taking it apart. did that, reconnected battery... but screen came undone from unit and can't get it to work agin. player works now and recharges too but hard to use wo screen. only had it one year. ********** with zen support..
  • 4 more comments
  • chrish2889 Jun 06, 2008
    how do you connect it properly? might be hard but can you describe in more detail?
    no one shows it well
    yes many times! they say it is hard and it is. hard to see what they are doing....
    i'll send some pics or maybe a video.
    thanks SOOO much!!!
  • chrish2889 Jun 07, 2008
    I try and try and can get it to go in a little but then it comes apart when i try to put tape on it. sometimes i do this when it is on-- wouldnt there be some flicker on the screen if it was somwhat connected ? i am wondering if there is power to the screen afterall and dont have a meter. how would power have been lost to the screen? did i touch something on it that made that happen and can i jump start it anyway?
    i do see a couple pins missing....
    the cable has gotten a little bent on one side and 2 ? pins are missing from the device. It can't work with most of the pins, then? do you know what may cause screen to lose power? -- curious about that.
    thanks for your help!
  • chrish2889 Jun 08, 2008
    well, i may take it in and see what they say. I could buy a different brand for less probably though... bummer!
    thanks for all your help!
  • 3,037 Answers
You will have to open it back up and make sure the cable from the screen is connected properly
Let me know how this works out for you and whether you have any more questions
Posted on Jun 06, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Jun 06, 2008
    take a few pictures of the connection you are having problem with and email them to me at bestdarntootingood@yahoo.com so I can be as specific as I can with your device.
    I know this is hard but when reconnecting the cable, it must be pressed all of the way together in the connector, try using tweezers if you are having trouble and make sure you keep the screen as close to the connection as possible when assembling as it may pull back out.
  • Benjamin Patri
    Benjamin Patri Jun 07, 2008
    the screen is on correctly for one thing ok...
    Now if you had the screen hovering directly above the rest of the device in proper orientation, you should be able to slide the cable into the connector like you said you tried. This is correct.
    To do this, tilt the top of the screen in the direction of the bottom of the unit and slide the connectors together and the metal pins should be touching each other. Now you referred to the tab that moves up and down, this should lock down in place on top of the cable connector to secure it in place and then you should be able to put the face plate back onto the unit and it should work. If it still doesn't let me know, but first check for broken pins, (these are the little metal pieces connecting together and also see if there is any power running from the device to the screen if you have a meter to test this. Let me know how this works out and if you run into any trouble and thanks for the video.
  • Benjamin Patri
    The pins are missing from the cable I assume. See if they are also missing from device connector. If not, you can either buy a new screen or first you can take it to an electronics store and have them look at it quick for you and see if they could fix it for you for a cheap price.
  • Benjamin Patri
    certain pins are in charge of certain things, the pin that supplies power probably is the one missing if nothing comes up on the screen. there could also be a loose area in the cable at the connector if pins are missing
  • Creative Labs Master
  • 13,433 Answers
Not sure is the screen broken, check all connections.
  • Ekse Jun 06, 2008
    have you watched this?
Zen V Plus freezing at re-building library
Hello Dear
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Apr 05, 2009 | Creative Labs ZEN V Plus MP3 Player
How to change the battery
Have you tried going to the www.creative.com/support site? It's a very informative site for my ZEN V, even though I still can't figure out how the LCD display went black and has never recovered. I hope this helps.
Oct 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Aug 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V Plus doesn't power on after recharging
Just kept pressing the reset button and it worked, really annoying though.
Jul 21, 2008 | Creative Labs ZEN V Plus MP3 Player
My zen is frozen
try to reload the firmware. download the firmware from creative.com. hold the play button when turn the player on, that will lead you to the recovery mode. chose reload firmware and then connect to your PC. run the firmware downloaded.
mick2a: the screen is gone. you need to replace it.
Jul 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Black Screen, Not turning on but charges?
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 06, 2008 | Creative Labs ZEN V Plus MP3 Player
My zen v mp3 is frozen, everytime I let the battery drain so that i am able to recharge it, it either doesn't work or i have to get a body pin and press the reset button. When i do this my zen only shows...
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Jan 26, 2008 | Creative Labs Zen V MP3 Player
Zen V 1gb
Dec 14, 2007 | Creative Labs ZEN V Plus MP3 Player
MY LCD screen will not turn on!!
Read this:
http://www.anythingbutipod.com/forum/showthread.php?t=18859
try this:
Nov 10, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
