Question about GE 25952 Cordless Phone
My cybershot phone dosnt display any letters other than E,I,O,U
BEST SOLUTION IS EASY TO SAY, BUT HOW DO CHANGE LANGUAGE SETTINGS? OR RESTORE THE SETTING TO ENGLISH. ALONG WITH THIS, HOW DO I RESTORE THE ANSWERING MACHINE COMPLETELY? MY ANSWERING MACHINE IS OFF COMPLETELY
Posted on Oct 27, 2008
  • 3 Answers
Its because the language format is wrong just restore an change language settings
Posted on Jun 07, 2008
How do i access phone numbers from my phone
Search for a contact
Press the open Menu button
Use the arrow keys to select Personal. Press OK.
Use the arrow keys to select Options. Press OK.
Enter the first letter of the name you are searching, e.g. K
The first name found with the letter K is displayed
If you are looking for a name that begins with Kr, also enter the second letter in the search field:
The first name with the initial letters Kr is displayed
Use the arrow keys to find the name
Press OK to select and call the contact
Oct 03, 2016 | Uniden Cordless Phone
My nokia 6085 does not display screen & every time automatic switch off? what isproblem of this?
my phone dose the same thing i wish i could help but it dosnt seem to be fixible i suggest take the sim card and get a samsung they are reliable and durible
Nov 15, 2010 | Nokia 6085 Cellular Phone
How do i change my phone from numbers to letters
I am not sure about the brand & model number you are using. But in NOKIA phone you need to PRESS # for more than 5 Seconds then it will change to letter, word & vice versa.
Thanks...!!
Oct 17, 2010 | Lands Phones
How do I chance the names on an NEC phone
NAME DISPLAY
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
entered
Apr 05, 2010 | NEC Dterm DTP 16D-1 Corded Phone
My sumsung SGH-E250 FREZZES SOMETMES WHEN SWICTH IT OFF AND BACK ON THE LETTERS BECOME UPSIDE DOWN.
the problem can be solved.The phone has two fault:
the freezing of the phone
and
the upside down letters.
The freezing the phone is caused when there is virus infection on the phone or there is an application that is affected.
The phones memory has been corrupted and it needs to be restored by flashing the phone.
And for the upside down letters, when the flex of the phone that is connected to the front board that makes the screen display has cut, it starts to display funny letters. So the flex of the phone needs to be replaced with another one for those funny letters to stop.
Take care and good luck.
Mar 17, 2010 | O2 Samsung SGH-E250 Cellular Phone
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
I replaced the led screen but screen still dosnt light up why?
Hi!... I suspect your problem is not with your LCD. Have you tried changing the batteries? If not try it and if problem persist then the problem POWER not the display.
Oct 01, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How di I get my K850i to show the time in screen saver mode
Press the volume button on the side of the phone to display a screen similar to previous Sony Ericsson Cybershot phones during standby mode. It will display the time and a message icon. This is probably an energy saving feature when the screen goes black in standby mode, but you must press the volume button to get to that screen.
Feb 25, 2008 | Cell Phones
GE 25952 Cordless Phone Logo
67 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
