Question about Panasonic Televison & Video
We have a panasonic bbe 32 inch flat screen tv that is 4 years old that just stopped working. Apparently by reviews we aren't the only ones this has happened to. Is there a fuse or a part inside that is causing this and is it something that can be repaired?
5 Suggested Answers
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
ladywinn
  • 5138 Answers
SOURCE: sony 52 inch hd widescreen projection tv
You need to pull the top back off be very carefull that you do not break mirror clean mirror and all 3 tube lenses this should make a diffenrents in picture.
Posted on Feb 19, 2008
SOURCE: Panasonic Flat Screen Model No. CT36HX42F won't turn on
the 2SC5612 transistor near the fly back transformer is shorted
Posted on Oct 18, 2008
Ecollier2012
  • 3459 Answers
SOURCE: convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Panasonic 36 inch flat screen tv 6 years old (model unknown) just stopped turning on. Act as if it is unplugged. Could it just be the fuse? If so, where is it located and how do i replace?
Fuse sounds right.  Had a Toshiba 32" that did the same thing.  Had to have a repair man come out.  $150 charge all told.  Worth it, because a new TV would be a lot more.  Unless you are some kind of electronics wizard, you don't want to take that thing apart.  They are very delicate-looking inside (and really cheap-looking, actually!).
Nov 15, 2008 | Panasonic Televison & Video
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
