Hi, if you want you could try pressing Fn+Esc key to enable or disable your webcam or try updating first the drivers for your webcam. You can find all the drivers for your laptop on this website
http://tinyurl.com/2e35s6u. regarding your DVD rom you could try updating the drivers or try deleting the upper or lower filter on the registry and restarting your computer afterwards just follow this instruction on how to delete the upper or lower filters on the registry
1. go to start search or if your using XP go to RUN then type in there regedit then press enter
2 go to this folder HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318
3. look for the upper and lower filter and right click then delete. after removing those restart your compter
if this doesnt fix the issue you might consider replacing your DVD roam.
hope it helps
