Question about Nokia 6133 Cellular Phone
Can't place call
Hey, I need to know what these continual, north moving, blue arrows are at the top of my phone screen? I place a call and it looks like it's registering, but no sound is comming out?
h
If its a little icon at the top that means that it's transferring data, like a picture or text message
Posted on Jul 14, 2008
    Master:
  • 497 Answers
May i know ur model no. please
Posted on Jun 06, 2008
Can I connect my Bluetooth earpiece with my Safelink phone?
check the driver to up to date
re install software, but you must remove the old first so you will not continue to have the same issues
can you try sync the devices
you have to look at all anti virus programs and firewall settings
make sure you have fresh batteries in the head phone if the take them.
check the setting in the phone, go to settings than to account & sync
check application setting as well
make sure the program is not already running, look at manager applications also, than also look in the location and security setting under wireless networking
you also need to check the wireless and network settings,make sure the blue tooth is turned on
check the voice input and output section also
need to look on phone see if you 4 little dot on the lower side on either side of the lowest screen move your finger across the screen the screen should move that direction keep moving it until you find display of devices that are running to make sure the blue tooth is high lighted show that the device is on
Apr 16, 2015 | Radio Communications
Cant align screen..help plz..show me the way..xperia x1
my phone showthn screen and masage tap the target firmly and accurately ateach location on the screen .The target will continue to move until the screen us aliged
Feb 02, 2011 | Sony Ericsson XPERIA X1 Smartphone
How to hard reset intermec CS40 series?
on the top of the keyboard 2 arrows after like this < and > near the button Scan.
So knowing that.
Put the battery off, re-plug the battery.
Push the 2 arrows at the same time and press start button (red phone) continuing to press the 2 arrows...
you have a screen that gives you choices
Clean boot (Option 2 is a hard reset), press 2
press 0 to continue.
Hoping that helps,
John PIGERET
Mobility Consultant - Technical Project manager junior.
Dec 16, 2010 | Intermec CN3
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Asus notebook K501J Model. A blue wall at bottom of screen, about two inches high screen' .I cannot remove same. Also I cannot get the task at bottom of screen,
Try this:
Place your cursor at the top of the wide blue band. See if the cursor arrow changes to a 2-sided arrow. If if does, hold down the left button and move the cursor down until the screen is again normal.
Basically what you have done is to take part of the window and increase the size of the bar. This actually should be the taskbar, but it's way too large.
Oct 30, 2009 | ASUS K50IJ-C1 Notebook
Icons in the screen cannot be directly pointed. "if you click a specific icon the other near icon will respond"
Go into the Display inside control panel. In the second tab, choose Calibrate screen. Once done, it should work properly
Jun 08, 2009 | Sony Ericsson P910i Cellular Phone
GE DECT 6.0 Phone Light Blinks
First thing to try is to pick up handset or place on speaker. On the answer machine itself without trying to call your cable providers voice mail service...press the message button to ensure all messages have been heard or erased.
Second, unplug your phone power from the wall and wait two minutes before powering on the phone.
Last replace batteries in the phone if you have batteries in the phone now...may be low battery signal.
May 29, 2009 | Uniden Cordless Phone
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Nokia 6133 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
