Back to:
Tags:
Nakamichi PA-506 Car Audio Amplifier
Nakamichi vs. Phoenix Gold amps
By Bomber - usenet poster
I'm trying to decide which is the better amp to run my mids and highs.
 I'm split between the "Nakamichi PA-504 400w 4-Ch Amp" and the
"Phoenix Gold ZX475ti 75X4"
 Can anyone give me some idea of which would be a better choice for my
application?
 Which amp produces better sound for mids and highs?
-Chris
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Pasty
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In article <e4aY6.98029$G5.20865 @news1.rdc1.md.home.com>, "Overt" <a @soundsolutionsmd.com> wrote:
ZX amps are very clean.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Nakamichi vs. Phoenix Gold amps:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Jimmy NY
Rating: 0%, 0 votes
I have used Nakamichi PA506 quite some time. PA 506 is 50w x 6ch (at 4ohm), and PA504 is
50w x 4ch (at 4ohm). The sound quality of Nakamich amplifier is very good, however it
gets very hot indeed.
In Japan there was modified version available which eased the getting-hot problems.
Phoenix Gold Titanum series amplfier is also very good one for sound quality and you
don't get the heat like Nakamichi's.
If you normally play longer hours in your car, I would rather not recommend Nakamichi
amplifier.
Cheers
Jung-Ho, Ahn
TeamAMP #042
TeamROCS #123
Thank You!
Solution #3
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
The Nak hands down.
The PG is a brute....alot of power but no class.
Thank You!
Solution #4
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
The Nak is nice but you'd be giving away a little bit of power to the
PG amp. That being said the PG ti series amplifiers still have great
SQ when set up properly. Heck I've got a 50Wx2 section of my PG Outlaw
running my Dynaudio's and it's still sounding very clean...
On Wed, 20 Jun 2001 23:11:06 GMT, "Overt" <a @soundsolutionsmd.com>
wrote:
Stephen "Canuck" Narayan
ICQ UIN# 23618874  | IRC Steve-N on EFnet | snara @sympatico.ca
TeamAMP Member #034 | http://www.teamamp.com
teamROCS Member #068 | http://www.teamrocs.com
FS: Sony CDX-C910 AM/FM/CD Player, DEI EQ4500 indash preamp/EQ, Peerless XLS 12" sub.
Thank You!
Can you Help with these Car Amplifiers problems?
Car Amplifiers
you can request for more solutions by requesting solutions...
Car Amplifiers
burned 2 circurt on the power cable side on the top and on...
Car Amplifiers
need help with installing this amp
where can i get one?
i have a nakamichi pa-506 and it goes into protection when...
Loading problems.
Repair Service
Find Car Amplifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
