Ecoquest Living Air Classic Air Purifier
Problem for Ecoquest Living Air Classic Air Purifier
Living Air XL-15 Classic - Foul odor!
By cant standit on Jun 06, 2008
About 6 mos ago my unit started to emit a foul odor. It smells organic like a lake or something. It isn't constant but I can't get it to go away! I bought new plates and filters since mine were pretty old. I have cleaned it thouroughly with alcohol and nothing worked. When I put a new clean plate in, it smells ok for about 2 mins then it starts to smell. HELP. I know sometimes the ozone can react badly with somethings (like Paint fumes) but I can't imagine what it could be reacting with, nothing has changed in my home. My house stinks and its embarrassing!
Comments:
Jan 06, 2009
- Thanks for the comments, I have tried the ozone level adjustments but it is still there.. I actually like the smell of ozone it smells like rain. I have contacted living air and all they told me was to buy new plates and filters, which I did, but nothing worked... my only other option was to buy a new unit but times are tough and I really cant afford it right now. So I guess I am just stuck for now. Appreciate your help.
Best Solution
posted on Dec 23, 2008
Helpful)
JSEhandyman
Rank: Guru
Rating: 91%, 126 votes
Hi cant standit,
Can you control this odor by adjusting the ozone (O3) control? High levels of O3 smell obnoxious or irritating to some people; you want a fairly low concentration (~40 ppb - that's parts-per-Billion, not much).
It sounds like you've done everything else right. Have you consulted with the dealer you bought from? How about EcoQuest? If it's not the O3 level being too high, then perhaps there's something goofy with the unit. If it's under warranty, pursue that option. You should have contact infor with the unit; respond if you need it and I can post it.
Let me know.
Comments:
Jan 07, 2009
- OK, I sure understand about not wanting to spend the $$$.
When you cleaned it, did you completely tear-down the chassis (removal of the 4 screws in the bottom, ease-out the power switch to disconnect the wires, unplug the fan terminals, etc.) so you could pull the whole chassis clear of the outer case. Be careful, those fan motor spade terminals can corrode with long term (5+ yrs) use.
I'm trying to figure if it's the case, or something hinky with the electronics. You comment about it being "organic" makes me wonder if something is perhaps amiss with the cabinet (possibly the chipboard got wet at one point and is growing that smell?)
It doesn't cost us anything to talk back & forth, and I'd like to figure this out.
Jon
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Living Air Classic
Questions and Unsolved Problems for Ecoquest Living Air Classic
Do you recommend Ecoquest Living Air Classic Air Purifier?
Answer
Answer
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I... (More)
Answer
no high voltage to grid after 5 minutes operation
Answer
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky... (More)
Answer
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is... (More)
Answer
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Living Air Classic...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
