Question about Compaq Presario 700 470024-192 Notebook
Having compaq presario c700 facing cound problem......
I have a compaq presario c700 (instaalled windows xp) and i am facing microphone problem it's not working but speaker's is working properly.even i have a headphone but voice not going even my headphone's mic is working other laptop as well as Pc.
pls give me sollution for that.
Thanks.
  • 2 more comments
  • Anonymous Jun 09, 2008
    plze help me. I am also having the same problem.
    My compaq Presario C700 mic is not working at all...
  • Anonymous Jan 16, 2009
    I have the same problem but my OS is Vista. There is no microphone activity when I do call set-up on either Yahoo Messenger or Google talk. I have to reset my laptop in order for the microphone to work again. The output of Microphone is distorted...
  • saathi Apr 17, 2009
    Audio is coming out even after inserting head phone pin to the socket of my compaq presario c700 (with os windows xp).
    Novelist:
    Scholar:
  • 99 Answers
Not sure why people say mic doesn't work in xp I have never had a problem. I can suggest this though. Oh the taskbar right click the speaker icon and select: Recording devices. a window will open showing all recording devices enabled. your mic may just be disabled so easy to enable it from here. Right click in the window and select show disabled devices. Now 2 things you can do here if you mic shows disabled. double click it or right click it.
Double click will open Microphone properties. Near the bottom of window will see device usage. It will probably be saying: do not use this device (disable).
Just open the drop down menu and select
Use this device (Enable)
GO THROUGH EACH TAB AT THE TOP: Listen Levels .......
I would suggest to just go to Levels and check to make sure that the Microphone is not at 0 and the same with the Microphone Boost. (if applicable) Also make sure that the speaker Icon is not x out.
Click apply then ok.
You are taken back to the recording listing. The mic should appear in bold outline with a check next to it. And once again click apply and ok. Should this not help reopen the window go to properties and click the advanced tab. Select restore default then apply and ok etc.
I hope this helps anyone having mic issues regardless version of windows from xp - 8.1
Posted on Sep 25, 2014
  • Matthew Slattery
    Matthew Slattery Oct 10, 2014
    There are many program you can use to obtain and install drivers for you, however those programs do not always give the right drives. cnet's program gives out dated Drivers repeatedly, Drivemax just throws any driver regardless that it doesn't match, at you. If you can't determine the right driver even from the part manufacture/provider then I would suggest using Slimdrivers from Slimware utilities. I have only been suing it for the past 3 years or so myself but have not run into any problems obtaining correct drivers. Let me put it this way. it scans all drivers logs into the appropriate site to obtain the updates and gives you the option to update or ignore, I've noticed over the year Microsoft fails to retrieve updates if you go through device manager.
    My compaq with vista (bought 2009) had driver problems when I first got it . tred various top programs suggested by Maximum pc and pc world. All failed. Not to mention most where only partly free. Or just scans then have to buy the programs. Slimware does have a paied for version that will automatically scan for updates but seems a waste of money to only get updates once every few months or so for drivers.
    PC manufactures fail to stay up-to-date in providing correct and most recent updates for drivers, Usually a few versions old. Slimware goes directly to the part manufacture to get the updates no searching obscure third parties sites.
    But as I stated prior in first response I gave best to check to make sure that mic settings are on and volume is up etc. Try to restore to default then if still no mic update driver(s). I have noticed that sometimes if you add an external m ic to laptop with on built-in, there can be a conflict between them. Should this be the case just go to recording device and turn one of them off.
    Problem Solver:
  • 10 Answers
Hi Friends,
Compaq Presario 700 PC Notebook's main problem is audio driver for win xp.
For Audio driver software you can visit a link by just
Click Here .
For any other problems with this Notebook you can
Click Here .
Posted on Jul 22, 2010
I have solution for Compaq Presario C700 C734tu Laptop. In My laptop Sound was working properly, only the problem was MIC was not working. So after googling I found this link for Sound Drivers. It may help you.
http://webpages.charter.net/mmooglemirror/Compaq%20C751nr%20Audio%20XP32.zip
Regards,
Alpesh Bhavsar
Posted on Aug 13, 2008
Hey guys for all those that think c700 series doesn't support xp sp 2
now i hv a good news!!!!!!!!!!!!!!!!!!!!!1
for at least audio and mic problem
use this link and have a fix on the audio problem
http://www.mmoogle.org/compaqc751nrwindowsxpdrivershowto
if u got it fixed plzzzzzzzzzzzz comments
regards mandan mishra
Posted on Jul 27, 2008
  • 58 Answers
Hey!
we have to face it, the microphone feature is not working on XP. i've tried to install it a millionth times, no go. it's working very well on vista. if you want, you can just try to do dual boot. both XP and Vista in one system. just a suggestion though...
Hope this helps!
Thanks,
Karlox™ :)
Posted on Jun 12, 2008
I have Compaq Presario C700 Widescreen laptop , my microphone which is next to web camera is not working,
try this web site to download the driver for the mic
http://www.zyxware.com/articles/2008/12/04/compaq-presario-c765tu-laptop-drivers-for-windows-xp
Mar 13, 2010 | Compaq Presario 700 470024-192 Notebook
Sound Driver of a Compaq Presario C700 Notebook PC
I am facing problem of Sound Driver. I am also using Compaq Presario C700. Thank you for sorting out my problem.
http://www.joomladesignservices.com/684-going-mobile-with-your-joomla-cms-portal.html
Nov 20, 2008 | Audio Players & Recorders
Compaq Presario C700 series C794WU Laptop audio driver for windows xp
hi sir i have need presario c700 series audio driver
because my audio driver unstall by mistake
plz avlable this driver winxp
Oct 18, 2008 | Compaq Presario C700T Notebook
Sound drivers for win xp
drivers for presario c785tu
Sep 16, 2008 | Compaq Presario Notebook
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Driver Compaq Presario C700 notebook
i need compaq presario c700 notebook vga,sound,wireless drivers for windows xp.
Jun 25, 2008 | Compaq Creative Sound Blaster PCI 128...
Microphone Presario C700 not working
Just download audio driver from this link
I am sure it will work.
May 02, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
766 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
